stock clutch go bye bye
Old Oct 2, 2008 | 09:47 PM
stryfetew's Avatar
Went to the track tonight for the first time in the car 1st run 13.4 @ 109 with a 2.33 60ft.. Gag... Next run 2.002 60ft and a 13.1 missing third gear. Final RUN keep in mind 15-10 minutes or MORE between runs hit a 1.910 60ft and 12.54 @109 leave the track clutch slips horribly. Seeing as I need to get a clutch yesterday 4ws has said go with ACT HD with stock flywheel how much do these hold? goals for the car are 11s and 400whp thats all.
Old Oct 2, 2008 | 09:55 PM
Protostar1's Avatar
Ive heard good things about the Fidanza 3.2... for what its worth. I think it falls into the same catagory at the ACT, might be good for a bit more power. Just saying to check that out!
Old Oct 2, 2008 | 09:56 PM
stryfetew's Avatar
I'll look into it as well gotta get something kinda quick to get the car back running, it's not a dd but i do enjoy driving it
Old Oct 2, 2008 | 09:57 PM
Slovo's Avatar
Exedy twin disc... you will have no complaints! Well worth it!
Old Oct 3, 2008 | 05:40 AM
stryfetew's Avatar
I would love to get the exedy but the price difference between act and exedy iis crazy.
Old Oct 3, 2008 | 05:54 AM
MR Turco's Avatar
I was all about the Exedy but i think i am now leaning towards the quartermaster.
Old Oct 3, 2008 | 06:10 AM
binky's Avatar
I had the same problem - haha
I am just finishing up my clutch install. I bought an Exedy twin disc HD.
I have to say, if you are going to do the install yourself, you will THANK yourself by spending the extra $$ on the Exedy. Just knowing you won't have to go through replacing your clutch again anytime soon was worth it to me.
-Bink
Old Oct 3, 2008 | 06:20 AM
Smike's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=366681
F3.2 > ACT HDSS in my book. Easier to drive, quicker shifts, no sore ankles...
Old Oct 3, 2008 | 06:26 AM
BorisTheBlade's Avatar
The exedy may be more, but it is definitely worth it.
Old Oct 3, 2008 | 08:34 AM
jpetro10's Avatar
what RPM do you shift at? I know I shift at about 7.2k and I just got the ACT Sprung 6 Puck and its awesome. I have yet to get lock out probably because I shift a little earlier than most but at almost 3800ft I loose power if i go any higher, lol. But I should be in the 11's next time I go and I learn how to launch it and this clutch holds the power awesome, shifts great, and like I said, I have yet to get locked out. Once I make over 450hp I might spring for the quartermaster, but it was just to much to spend right now, lol!
btw I went with a new exedy street light flywheel since mine was toast and this combo feels great.
Old Oct 3, 2008 | 09:32 AM
stryfetew's Avatar
I would go with the exedy but i just can't afford it. Looking at the ACT 6 puck sprung as well now. got a good price quote from no limit for the entire combo. when changing clutches I know you need to change tranny fluid but what about transfer case?
Old Oct 3, 2008 | 11:11 AM
Smike's Avatar
Yes, change the trans and TC fluid. TC drained - makes it easier move around.
Old Oct 3, 2008 | 11:17 AM
Billy@EnglishRacing's Avatar
true
Old Oct 3, 2008 | 11:51 AM
stryfetew's Avatar
Just ordered the act 6 puck sprung with street disc pressure plate and gruppe-s flywheel
Old Oct 3, 2008 | 12:53 PM
Duh Panda's Avatar
ouchhh... good luck with that
