evo8 turbo compressor wheel
Old Oct 10, 2008 | 04:16 AM
moak89's Avatar
my compressor wheel is damaged. i want to know where could i buy one from.
preferably used. or even new.
so can someone please help me out somehow then that would be awesome.
its a TD05HRA-10.5T. if the non Titanium Alumnide compressor wheels (from the TD05HR) are the same dimensions then one of those will also do.
or even if the 9.8T compressor wheel work in the 10.5 housing. i would still be interested.
let me know where i could find one.
thanks
Old Oct 10, 2008 | 04:18 AM
sharkm87's Avatar
you can always check the for sale..people are always sellin stock turbos for couple hundred.
Old Oct 10, 2008 | 07:09 AM
moak89's Avatar
i just need a compressor wheel...the rest of the turbo would be useless for me.
what i found out is that a brand new compressor wheel is for like $80-100
i wanted to know if someone knows where i can get a used one for.
thanks
Old Oct 10, 2008 | 07:11 AM
Kracka's Avatar
Just buy a used Evo VIII turbo; they are cheap. If you buy just a new wheel you'll have to get it professionally rebalanced anyway so it'll end up costing you more.
Old Oct 10, 2008 | 03:27 PM
moak89's Avatar
to be honest. cant afford one right now. therefore looking for just a used compressor wheel.
anyone know of guys who rebuild the td05hra turbos? they might have a slightly damaged one laying around that would do for me.
Old Oct 10, 2008 | 08:25 PM
sparky's Avatar
Originally Posted by moak89
...its a TD05HRA-10.5T. if the non Titanium Alumnide compressor wheels (from the TD05HR) are the same dimensions then one of those will also do...or even if the 9.8T compressor wheel work in the 10.5 housing.
The titanium-aluminide alloy material was used in the turbine wheel and not the compressor wheel. The VIII 16G turbos all have Inconel steel compressor wheels AFAIK. So, as others have mentioned, you can use any 16G VIII compressor wheel as it will be identical to your existing comp wheel.
How did your comp wheel get damaged anyway? Was it due to ingestion of foreign material, compressor surge, failed bearings, or something else? You may want to call a reputable turbo shop that specializes in rebuilding MHI turbos, such as Forced Performance, or Blouch Turbo and get their opinion.
They would be able to tell you if you can just swap a comp wheel onto the shaft without VSR balancing the CHRA.
Old Oct 11, 2008 | 05:42 AM
Steve93Talon's Avatar
The MHI wheels that I've seen come factory balanced. There's a difference between component balancing, which is how most OEM turbos are built, and assembly balanced, which is how most race turbos are made. You can remove the wheel and replace it with a different wheel, and each component will still be balanced. Is this as ideal as a whole rotating assembly that's been balanced? No, but it probably wont be any worse than how the turbo came from Mitsu.
You're thinking of turbine wheels. Most MHI 16g wheels are aluminum.
Here's a place that sells new wheels, just copying a link someone else posted on this forum, no experience with them (prices are in Australian):
http://www.gtpumps.com.au/wheels.html
Old Oct 11, 2008 | 08:14 AM
ForcedPerformance's Avatar
Forced Performance has cartons of these wheels, new and used. If ANYONE ever needs a stock EVO8/9 compressor wheel and they are in our customer files having purchased from us before I will give them one for free.
Old Oct 11, 2008 | 08:22 AM
nils's Avatar
awhhh.. the crying baby seal softened you up... now youre giving stuff away!!
n
Old Oct 11, 2008 | 08:28 AM
Ha! Always had a soft spot for a hardcore racer dude on a budget trying to piece the ride back together man. Been there toooooo many times myself
Old Oct 11, 2008 | 08:30 AM
jid2's Avatar
Very nice. That's cool.
Old Oct 11, 2008 | 12:04 PM
hokiruu's Avatar
Old Oct 11, 2008 | 01:50 PM
sparky's Avatar
Originally Posted by Steve93Talon
...You're thinking of turbine wheels. Most MHI 16g wheels are aluminum..
You´re correct! Thanks. My F**k-Up.
Old Oct 12, 2008 | 01:40 PM
moak89's Avatar
@sparky and Steve93Talon. thanks for the explaination bro.
so all evo8 comp wheels are the same.
@ForcedPerformance. thanks for understanding bro. uve got a pm. hope we can work something out... as i haven't bought from you before.
Old Oct 12, 2008 | 04:46 PM
so all evo8 comp wheels are the same..
There is a magnesium TME wheel, otherwise they're all the same as far as I know.
