weird problem on my evo
jcdevo67,Mine is also the same problem as per the OP, i hope someone can advise on this. I can only bring my car to the workshop this week end, until then was thinking i can get some info from here at least i know what to expect.
Anyways what do u guys mean "sticking"? Sorry for the noob question
Also when the fuel pump fails the car should not be able to start at all right? When the issue happened my fuel pump is making a funny whine noise like the ambulance sound (not the usual walboro whine), the sound can only be heard when the lean idle happens
If you notice that noise again, go behind your passenger seat (left side where fuel pump is located) and listen carefully. Is the noise coming from there? If not, then go behind under your bumper (where SAYC locate) and listen... is the noise from your ayc pump? If it is, that should happen and your SAYC pump is working...
Raceghost
Jun 1, 2016 12:30 AM
CDrinkH2O
Sep 7, 2013 05:51 PM
ziad
Jun 12, 2012 08:22 PM
Mellon Racing
194
Apr 12, 2012 04:45 PM
