HKS 272 Cams, what is the verdit?
^ your missing what I'm saying.. GSC and kelford are better then the 'old' style HKS. But HKS Japan are now starting to sell a new cut, also there is a Step 3 'race' cam that is available, but only through the correct channels and ONLY from HKS Japan.
Not saying these new ones are better, as they are RARE and not many people have used/tested them. I have seen them make gains over Tomei 280* 11.5mm Procams.
Well you may want to do a tad more research....Although the Kelfords and GSCs can make great power, there have been a number of posts regarding poor MIVEC oil grooves and the cam failing and thus destroying the engine. Kelford and GSC allegedly use the same cores (along with Cosworth) and all have had the problem, yet the HKS use a different core and have no reports of failure....
Nothing other than they seemed to be about 20whp less than the S2s. I am not sure if you are counting them since they are 274/274, but in that "class" they are very hard to beat.
Are you referring to GSC's new S2s or the one tested around the same era as the AMS cam test?
AMS cam test is old now. Too many new cams on the market.
