Little help/Info
Old Oct 13, 2008 | 11:22 AM
poon_slayer's Avatar
Little help/Info
Ok I just bought my Evo about 4 months ago now. I truely love the car and I have not thought about another car ever since.
It's a 2003 I believe fully loaded. It came with Buschur turbo back, hbc MBC, Cone filter intake, Grounding kit, And definetly a fuel pump (walboro are pretty loud). With that being said my A/F gauge when idling stays in the lean for a good bit of time then jumps around.
I noticed in my cousins boosted G35 it stays in the orange and never really runs lean at all. Basically does my car need a tune? I took it to the track and ran 12.8 with about a half tank of gas and cam2 race fuel (like 3 gallons of it) shouldn't that be close to what most would run stock? Oh and if i get on the gas I can literally watch the fuel burn by watching my fuel gauge go down.
I have been quoted by a pretty well known shop here in columbus 450 bucks for a reflash and tune. Just wondering if thats what my problem is with running so lean sometimes and the fact that I burn gas pretty damn bad. 220miles to a full tank.
Old Oct 13, 2008 | 03:08 PM
chaotichoax's Avatar
well at idle you should be around 14-16 afr
sounds like your cousins boosted g35 is running pig rich if at idle it's no less than 14
you definitely need a tune if you want to run better and have a more powerful car
Old Oct 13, 2008 | 03:12 PM
FQ-300's Avatar
220 miles per tank is decent if you are on it, meaning "in boost" frequently. Use EvoScan to check out some data and see whats going on. If all else fails, shoot Chris from Mellon Tuning a pm and describe your situation.
Old Oct 13, 2008 | 03:13 PM
speedypollard's Avatar
yeah, you need a tune...bad. until you do i would baby ur car
Old Oct 14, 2008 | 07:58 AM
Alright cool thxs for the feedback.
Old Oct 14, 2008 | 12:39 PM
Mellon Racing's Avatar
adding race gas will make you very rich and that could be killing the performance. I would get a proper pump gas tune and see how it runs then if you want more do a separate race gas tune for more boost to extract even more ponies.
FQ-300 thanks for the referral
Old Oct 14, 2008 | 01:59 PM
ETS Michael's Avatar
What type of A/F Gauge are you using? Is it a true wideband gauge? or an Autometer Gauge?
If it's one of the $50.00 autometer gauges chances are it's reading closed loop and just doing a nice blinky light dance. The easiest way to get a good a/f reading is using a true wideband. (AEM, Innovate, etc.)
Thanks,
Michael
turbocheese
16
Nov 19, 2015 09:16 AM
jspecteggy
12
Feb 13, 2015 10:00 AM
mrfred
E85 / Ethanol
174
Jun 3, 2014 06:50 PM
xtruemassacre
May 2, 2014 01:05 AM
goofygrin
86
Aug 6, 2013 08:09 AM
