Pure Tuning Borg Warner S259 Dyno Results!
Old Oct 14, 2008 | 10:13 AM
RazorLab's Avatar
Originally Posted by MR Turco
I guess for street i dont see the point of this setup. You make the same power with less lag on a IX turbo.
440 whp on a mustang dyno, on 93, with a IX turbo? lol
Old Oct 14, 2008 | 10:23 AM
mandy1's Avatar
torque curve looks better at 23psi,seems that at 37 have some backpressure issue,also hp falls down to fast at 37psi,cams will help,but i have make flatter hp & torque curves with hks 272 than this with gt35r .63,i think the problem should be the exh housing. thats my thoughts.about the 10% diference from the mustang dyno,its true,i even see more on rotary engines.but i love the load simulator.
Old Oct 14, 2008 | 10:24 AM
MR Turco's Avatar
Oh i read the graph completely wrong.
Old Oct 14, 2008 | 10:42 AM
Keith-PURE Tuning's Avatar
Former Vendor
An Evo IX turbo will not make the same number on 93oct on a Mustang Dyno! Again what point of reference are you using????
I must be Dynojet or Dynapack.
Show me a IX turbo that makes 440whp at 23psi on a factory calibrated Mustang Dyno and I will rescind my statements! I would believe what you said if this were a Dynojet, but not a Mustang Dyno!
Hear are some other graphs of some Evo 8s and 9s we have built on pump and race gas for a better point of reference.
05 Evo VIII
Stock Motor
Stock ECU
Stock Intake Manifold
24psi
93oct
This is a direct comparison of the OE Evo8 turbo vs the OE Evo9 turbo at the same boost.
06 Evo9
Stock Turbo
Stock Motor
Stock ECU
26psi
100oct
06 Evo9
FP Green Turbo
Stock Motor
Stock ECU
27psi
E85
This particular graph is a car that was untouched by us for the first couple dyno pulls so we could see how it faired from Switzer's Dynojet to our Mustang Dyno. On the Dynojet the car made 435whp / 450wtq. The difference doesn't hold up to our 2WD testing of 8-10% from a Mustang to a Dynojet but we haven't directly tested AWD cars yet, but what you can see is a substantial difference in readings with the exact same car on two different dynos. Numbers don't actually mean anything without a point of reference to compare.
Old Oct 14, 2008 | 10:57 AM
MR Turco's Avatar
Sorry keith i read the graph totally wrong. my apologies.
Old Oct 14, 2008 | 11:48 AM
leecavturbo's Avatar
more pics looks the nuts
Old Oct 15, 2008 | 02:14 AM
supersal's Avatar
hey Kieth - do you have graphs of a S258 vs. GT30R on your Dyno?
thanks
Sal
Old Oct 15, 2008 | 02:16 AM
Billy@EnglishRacing's Avatar
I like the kit, the manifold looks like it fits nice and snug
Old Oct 15, 2008 | 06:12 AM
Former Vendor
thanks
Sal
Nothing truly comparable. This car was done from head to toe. The few 30r cars weve done have had stock motors, a couple with stock cams, etc. Not realy a good comparo.
Old Oct 23, 2008 | 08:01 PM
partyboy1122's Avatar
I am considering this turbo. I may be getting a super deal on one. Are you saying the .70 a/r will not clear? and A/C will have to be removed?
Old Oct 23, 2008 | 08:43 PM
8UpUrV8's Avatar
Is this turbo Ball Bearing, Extended tip??
Old Oct 23, 2008 | 08:53 PM
8UpUrV8's Avatar
Keith,
Have you tested this setup with any other intake manifold?
Reason I ask is because there's already been results of a Stock Ported 65mm intake will outperform it...
Make more power possibly...
Old Oct 23, 2008 | 09:16 PM
I am pretty sure Borg Warner turbos are not BB.
Old Oct 24, 2008 | 07:55 AM
Former Vendor
I know I mentioned in previous posts we were going to be switching the intake manifold and cams to try and improve on the cars setup. I know I'm usually long winded when I post so you guys must have missed it.
We will be putting this on over the weekend to see the dyno results.
We are still waiting on the Kelford cams.
I'm not completely convinced an OE ported intake manifold will out-perform the Magnus street intake manifold on every setup.
The Borg Turbos are not Ball-Bearing.
The .70a/r would be the preferred one but this Full-Race maifold with that .70 turbine housing didn't allow the A/C to remain in the car. The Shearer manifold should allow the clearance but I haven't verified it yet.
Old Oct 24, 2008 | 09:40 AM
8UpUrV8's Avatar
Hope you have good results with the cast Magnus!
If you had the time to do a stock ported vs. cast or sheetmetal Magnus, that would give you some good clarification!
