Pure Tuning Borg Warner S259 Dyno Results!
Hey Keith, if you want to post up an overlay of my dyno graph vs. this one to show how dramatic the HP improvements are over a Green setup that is OK with me.
It looks like, compared to my car, this spools 1000rpm later, but makes ~70tq and 135whp more. . . I'd say a pretty good tradeoff!
The 2nd graph is the Evo8 w/Magnus V5 & S259 at 23psi vs Evo9 w/FP-Green & OE Intake Manifold at 27psi. I don't have a graph with the Magnus V5 at higher boost levels yet hence the reason for the older intake manifold in the first graph.
The cars power graphs are so different I made the lines for the FP-Green dotted for better differentiation.
Spool difference is about 700-800rpm at the same boost level.
As stated previously...The 2nd graph is the Evo8 w/Magnus V5 & S259 at 23psi vs Evo9 w/FP-Green & OE Intake Manifold at 27psi. I don't have a graph with the Magnus V5 at higher boost levels yet hence the reason for the older intake manifold in the first graph.
in case no one has mentioned it you can get the s362 in a s200 compressor cover it'll hurt the top end slightly but help the spool and response slightly
but i've seen a 2.0 vw make 31psi on a s362 with a .7o hotside by 4500 rpms
and rhe evo heads flow much better than the VW heads
The S362 uses a slightly larger turbine wheel 76.3/67.6 than the S200 turbos which are standard 74/64. Since the primary affect on spool is on the turbine side of the turbo (turbine wheel size and turbine a/r) to keep things consistent we will use the standard S200 turbine wheel size for these tests which keeps it in the S200 family. If we use the larger S300 turbine wheel size the tests would reflect more on the S300 frame turbos without direct relevence on the S200 family.
The S262 will be retained on the testing list.
How well does the correction factor account for weather changes such as temp? Isn't that what it's for? Ever tested a car on a hot day vs. a cold day to see how much power changed? That would be an interesting test . . .
Not sure how many extreme examples I have since we try to keep all variables as close as possible. If there are extreme differences in ambient air temps we baseline the car before testing is done so we can see how the car sits in the environment provided.
I am waiting for more comparable weather to finish this testing so I can use the old data already captured.
