Clutch Install = Me Stressed
Old Oct 14, 2008 | 01:43 PM
KS_Evo9's Avatar
Hey guys ill be posting up some pics tommarow of whats goin on with my evo. Im kinda stressed its ALOT of sh*t for your average mechanic (me).
PICS COMING SOON:
Old Oct 14, 2008 | 01:44 PM
Silver05Bullet's Avatar
come on man its not that hard the first time you do it it sucks but the next one is going to be way easier
Old Oct 14, 2008 | 01:47 PM
ETS Michael's Avatar
The clutch job really isn't that bad. Just remember to take your time. If you get a FSM (factory service manual), it makes it very easy with step by step instructions removing and installing the clutch.
Remember to resurface the flywheel, so you don't have to go back in there and do it again =)
Good luck and take your time!
Michael
Old Oct 15, 2008 | 03:17 PM
KS_Evo9's Avatar
Well I got the transfer case out today wasnt to bad. Now im on the transaxle and I cant seem to get it off. I wiggled it even flipped it around and it still wond come off. It gets almos all the way where you can see the whole flywheel but it seems like its getting cought on somthing when i KNOW theres nothing connected from the outside.
WELL HERE THE PICS \/
Old Oct 15, 2008 | 03:18 PM
KS_Evo9's Avatar
Old Oct 15, 2008 | 03:21 PM
KS_Evo9's Avatar
Old Oct 15, 2008 | 03:22 PM
KS_Evo9's Avatar
You can see the whole flywheel...... I dunno wdf its catching on.....
Old Oct 15, 2008 | 03:24 PM
griceiv's Avatar
did you pop out the throw out bearing before you tried to pull the trans?
Old Oct 15, 2008 | 03:31 PM
Evo9tunerz's Avatar
It should just come right off. Make sure you pryed the throw out bearing off first. If that doesn't work double check if there is anything else attached to the tranny. There's a good write up on evomoto.com if you need it.
Old Oct 15, 2008 | 03:32 PM
sharkm87's Avatar
ha..looks like you did the same thing i did.....u have to get that throw out bearing off first...push the trans back towards motor, and use a long flathead screwdriver....use your hand to surpess the TOB, and stick the screwdriver in there and rotate it to pop it loose
KS_Evo9's Avatar
WOW I dont think I did..... Thanks for schooling me you think I messed nething up?
Old Oct 15, 2008 | 03:34 PM
sharkm87's Avatar
of coarse not....even if you unsure how it pops out or looks.....you can stick your new tob in center of new pressure plate, and pull on it ...impossible to get off...once you push it in and twist with screwdriver..pops out magically
griceiv's Avatar
instructions attached.
Attached Thumbnails Clutch Install = Me Stressed-clutch-release-bearing-separation.png
Old Oct 15, 2008 | 04:01 PM
Evoryder's Avatar
should have read evomoto's guide.
Old Oct 15, 2008 | 04:04 PM
KS_Evo9's Avatar
Thanks Guys
Ill keep everyone updated with pics
