Turbo headaches...
Old Oct 17, 2008 | 08:33 PM
Romanoat's Avatar
Turbo headaches...
Alright, I've been having a problem for the past few days. When I boost to the full 24, my car starts bucking and losing boost, builds it back, loses it and bucks again. It's been bothering me and I can't quite figure it out. I think it may be my blow off leaking, (recirculated Forge valve), or my wastegate (Tial, dumped). I'm not sure. It seems like a leaky valve, but the BoV looks fine when I take it out. Any ideas? This bucking and low power annoys me, my car runs like poopy.
Old Oct 17, 2008 | 08:44 PM
sparky's Avatar
Had your car been running fine at the same 24 PSI previous to the bucking that you are now experiencing?
Old Oct 17, 2008 | 08:58 PM
Romanoat's Avatar
Yes sir, ran perfectly fine for a long time. That's why I'm confused. The more I think about, the worse my migraine gets.
Old Oct 17, 2008 | 09:07 PM
sparky's Avatar
Do you have an AFR gauge? What is your full modlist, BTW?
Old Oct 18, 2008 | 08:29 AM
VRSF Tiago's Avatar
The only way to know what's wrong with your car with an internet diagnosis is if you post a log of your car. There could be WAY to many things causing that kind of behavior and we could guess at what it could be, but if you post a log it'll be easier to pinpoint.
Old Oct 18, 2008 | 08:32 AM
ForcedPerformance's Avatar
If the car is making 24psi, then it doesnt seem like anything is wrong with the turbo.
Old Oct 18, 2008 | 08:55 AM
VRSF Tiago's Avatar
+1
Sounds like it's fuel/tune related.
Old Oct 18, 2008 | 08:57 AM
EE's Avatar
EE
Could be the wastegate actuator...
It happened once to me when i added preload to my stock wga... it's worth a look
Old Oct 18, 2008 | 10:36 AM
epson1's Avatar
Either blowing out spark, or hitting boost cut. Get new sparkplugs (NGKBPR7ES or BPR8ES), try turning down your boost controller just a little bit if that don't fix it.
Old Oct 18, 2008 | 07:56 PM
mt057's Avatar
i had a shop install my ebc for me and they switched the vac lines. it made my car build and lose boost rapidly. it felt like it would cut at 20/25 and then drop to 18 and fly back up over and over.
Old Oct 18, 2008 | 11:20 PM
bostonhatcher's Avatar
EBC solenoid is junk...
Old Oct 19, 2008 | 11:28 PM
Romanoat's Avatar
This has to be the problem, I just changed my plugs to NGK BR8EIX.
I'm going to pop in the BPR8ES and see if that fixes it. I'm probably killing the plugs at 24psi. I should have known it started happening after changing plugs, but I didn't spool the car enough to notice it until a few days after changing.
