Making the car shift better.
Old Oct 24, 2008 | 02:15 AM
meltdown's Avatar
Underhood shift bushings and a poly front motor mount.
Now I can shift hard and fast without the grinding and it goes into reverse like a hot knife through butter
Old Oct 24, 2008 | 08:11 AM
evolved83's Avatar
I have the following:
-underhood shifter bushings
-poly front motor mount
-Amsoil mtg tranny fluid...
The Amsoil fluid helps make the car shift like a hot knife through butter... definately recommended. I got mine from oil doc.
Old Oct 24, 2008 | 08:19 AM
j14mp's Avatar
blox mount... makes my car feel a thousand times better between shifts
Old Oct 24, 2008 | 08:25 AM
Evo8luva's Avatar
good clutch, front motor mount, good gear oil, and GET the Buschur shifter bushings, just put em in last night, all i can say is WOW.
i guess my stockers were fried lol.
Old Oct 26, 2008 | 05:01 AM
kapture2k's Avatar
Can anyone recommend shifter base bushings for a 6 speed? Or does it make a difference between the 5 or 6 speed as far as the shifter base bushings is concerned.
Old Oct 26, 2008 | 05:16 AM
BlackIX's Avatar
One other thing you should do is make sure your clutch pedal is properly adjusted. I've done all the bushings, front motor mount and clutch line but the one thing that got rid of my 1-2 crunch was adjusting the clutch correctly.
Here is a great video you should all check out with very detailed instructions on how to do it.
http://www.youtube.com/watch?v=vYJxQyjIhUw
Old May 20, 2010 | 07:28 PM
SPANKED's Avatar
Good vid, I need to adjust my clutch pedal for sure!
MisUnderStood
Feb 20, 2017 04:43 PM
MisUnderStood
19
Jun 3, 2016 08:37 PM
OneCrzyEvo21
May 24, 2016 12:45 AM
kaoscage
Jan 9, 2012 02:56 PM
freshpl
61
Dec 4, 2009 09:01 AM
