rerouting the throttle cable
Old Oct 20, 2008 | 08:01 PM
BorisTheBlade's Avatar
is there anyway to reroute the throttle cable so i can get it out of the way? ive seen several pictures of setups where it does not run across the valve cover like it does from the factory, any suggestions?
Old Oct 20, 2008 | 10:16 PM
Evo8luva's Avatar
you can run it behind/under the intake manifold, and have it loop around by the ABS module to come back to the throttle body. pm me your email ill send you a pic of mine!
Old Oct 20, 2008 | 10:24 PM
Evolessfornow's Avatar
Bend it back to form an S shape. Use the clip that held the throttle cable in the stock location and attach the clip onto one of the solenoid bolts on the top left of the engine bay. Insert the throttle cable on the clip and your done.
Old Oct 21, 2008 | 05:15 AM
StreetThisEvo's Avatar
That is how mine is routed. If you want just stop by and i'll show you how I did mine.
Old Oct 21, 2008 | 05:54 AM
pupo's Avatar
Anyone can post a picture? I would also like to get that cable out of the way.
Old Oct 21, 2008 | 06:23 AM
garcias2k's Avatar
This sounds like a simple mod. Any problems with it binding? Also some pics would be nice.
Old Oct 21, 2008 | 06:49 AM
antilag_200's Avatar
Here is how I did mine
and it what it looks like with everything buttoned up
Old Oct 21, 2008 | 06:55 AM
MitsuJDM's Avatar
I did this. It made my gas pedal too stiff and it felt like the trottle was sticking. I put it back and it was fine.
Old Oct 21, 2008 | 06:58 AM
garcias2k's Avatar
antilag 200, do you have any issues with the throttle sticking?
Old Oct 21, 2008 | 07:06 AM
Kracka's Avatar
No issues with mine; I've had it rerouted for almost a year. I just flipped it over and bolted the mount that was on the valve cover to the firewall.
Old Oct 21, 2008 | 07:10 AM
it does not stick at all, because the routing is smooth transistion along the firewall and then does a gradual sweep under the intake manifold ( vsr ) in my case. It has been routed this way for almost 2.5 years.
Old Oct 21, 2008 | 07:17 AM
injentech42's Avatar
my friend moved hes as well and felt diffrent so he put it back the way it was
CNOEVO22
Mar 20, 2015 07:01 AM
SUBE KLR
22
Dec 6, 2009 07:11 PM
Jameson_IXMR
Mar 9, 2008 11:34 PM
DiamondWhite
May 5, 2005 09:14 PM
Static
Mar 24, 2004 03:40 PM
