Clutch grind/creak/rub???
Old Oct 24, 2008 | 04:06 PM
gixxer6's Avatar
I got a cltuchmasters stage 3 installed (with stock flywheel because of lack of money) about a month ago and for about the last 2-3 wks ago it has been making a creaking/rubbing noise when the pedal is about halfway engaged on take off..the weird thing is that it only does it intitially, once its warmed up it stops.
Also when i hear the noise it feels like the cluth is trying to disengage/slip..maybe has to do with the throwout bearing? need some help
Old Oct 24, 2008 | 05:33 PM
gixxer6's Avatar
hmm no responses..should I move this to the drivtrain section..I figured it was too vague for that??
Old Oct 24, 2008 | 06:40 PM
1NASTYIXMR's Avatar
I had a bunch of cm clutches that did that same thing, all i can say is chose a diffrent clutch. There good for a drag racing and thats about it.
Old Oct 24, 2008 | 06:41 PM
1NASTYIXMR's Avatar
And also did you get your flywheel resurfaced when you put that clutch in?
Old Oct 25, 2008 | 01:18 PM
gixxer6's Avatar
as far as I know it was..
Old Oct 25, 2008 | 01:31 PM
1NASTYIXMR's Avatar
If it was not resurfaced than thats your problem, and now you will need a new clutch disc aswell
I would just get a diffrent clutch cause ive always had bad luck with cm clutches.
Old Oct 27, 2008 | 06:34 PM
gixxer6's Avatar
any other ideas?
GGMoe
Lancer Troubleshooting
Jul 12, 2016 01:03 PM
BlueRalliart
Sep 21, 2014 04:52 AM
jtcarstens
Jan 28, 2014 05:19 PM
Mitsu3
Jun 1, 2007 09:26 PM
ODUB
Apr 5, 2007 08:05 PM
