2wd evo.. wtf happened?
Old Oct 26, 2008 | 07:39 PM
Nasty Evolution's Avatar
Like the title says my evo is no longer awd.. ONLY the front wheels spin, on a launch. Smoke is more like it, on a nearly stock evo. If I do a hard 1/2 shift you can still hear the rear diff clunk but not nearly as hard or loud as it normally would.
Old Oct 26, 2008 | 07:44 PM
Celica2EVO's Avatar
sounds like you have a blown center diff. Time to send it to Shep for an RS or Quaife cinter diff upgrade.
Old Oct 26, 2008 | 08:18 PM
red evo8's Avatar
ouch lol do the rears even drive? i would lift the car up with jack stands and be careful with this as i've tried it before, lift it with jackstands all 4 corners and put it in first and see if the rear wheels even drive. I WARN YOU YOU ONLY EVEN NEED TO HIT 2MPH TO TEST THIS lol.
Old Oct 26, 2008 | 09:53 PM
I have not checked yet but I would have to say yes they do. It seem to suddenly work every now and again. I was able to do a donut on the wet pavement.
Old Oct 26, 2008 | 10:29 PM
Celica2EVO's Avatar
Its the center diff. You blew the teeth off the open diff gears. I did the same thing. The car will drive but then it will make horrible noises when you turn or hit boost and the teeth will slip. The noises you hear are when its missing teeth and then catching onto the next one.
Old Oct 27, 2008 | 06:59 AM
That's just it.. I'm not getting any noises or sounds. Only way we knew something was wrong was because the car suddenly was doing insane fwd burn outs.
Old Oct 27, 2008 | 07:41 AM
jayIII's Avatar
I had the same problem with my III, very iffy about where and which tires the power goes to.
I had a really loud clunk in the rear only when i turn and slightly when i luanch changed the rear diff and it was perfect. now i have the same problem but with the front, so my car is RWD alot more fun than FWD or 4WD 270+ hp in a RWD evo is more than enough to drift donut and smoke out the scene. But now i having to take her down and change the front diff.
Almost a gaurentee that its the rear diff or possibly the center diff.
Old Oct 27, 2008 | 07:44 AM
j14mp's Avatar
time to lay off them burnouts! lolol
JUST KIDDING!!! use that thaaannggg!
Old Oct 27, 2008 | 08:50 AM
EVOizmm's Avatar
I drove the car myself, and it seems just like a FWD car. My first guess was the Spider gears in the center diff.
What about the gears in the Front Diff, is that a possibility?
Old Oct 27, 2008 | 12:46 PM
Celica2EVO's Avatar
The front diff is inside the tranny and extremely unlikely. Its almost a certain that its the transfer case.
Old Oct 27, 2008 | 03:38 PM
I need to pick up a slide hammer tonight and then I will finish pulling the spider gears and report back my findings.
Old Oct 27, 2008 | 07:14 PM
justboosted02's Avatar
no, front diff is in the TC. center diff is in the transmission
Old Oct 27, 2008 | 07:18 PM
markymark1082's Avatar
+1 this is correct.
Correct! The front diff is in the T case.
Adding to that.. My front diff is in great shape. No broken spider gears. Ok so that leaves the center diff in the trans or the rear diff to be my problem.
Old Oct 27, 2008 | 07:29 PM
SpunEvoIX's Avatar
are you sure you don't have a reg lancer lol
