High revving issue need advice
Old Oct 29, 2008 | 03:03 PM
robogast's Avatar
Hello. I have an evo 8 with built motor and a fidanza flywheel. Lately , sometimes, when i am driving it and i get on it and go to shift in between gears my rpm rev up high. It only usually happens inbetween second and third or third to fourth. I thought it might be my throttle cable but i checked it today and i didnt find anything wrong with it. I dont know if it might be my IAC valve either. Ill prolly check that shortly. But im wondering if anyone else has ever had any problems like this. Need some advice. Thanks
Old Oct 29, 2008 | 03:04 PM
chaotichoax's Avatar
kinda silly but are you 100% positive you are coming off the gas 100% before you start to engage the clutch
chances are it's your shifting that needs work
Old Oct 29, 2008 | 03:06 PM
P-ROY's Avatar
^ +1
Old Oct 29, 2008 | 03:08 PM
robogast's Avatar
Yes im sure because i know what my feet are doing and i have had to pop the gas petal a couple times to get it to stop the first time it happened
Old Oct 29, 2008 | 03:24 PM
P-ROY's Avatar
are you sure the routing for the throttle cable is clear and easy to move.
maybe the spring at the end of the throt cable?
Old Oct 29, 2008 | 03:26 PM
DsmAwdTurbo's Avatar
I had the same thing with my 05. And so did every other evo that I drove. after you get on it try pushing in the clutch see if that relieves the problem. I know the 05's had this but it was from the factory for emissions or some BS.
Old Oct 29, 2008 | 03:35 PM
robogast's Avatar
Do you know what is causeing it to do that? I know its not the clutch cause its the same one i used before i rebuilt the motor. But ill try it tonight.
Old Oct 29, 2008 | 06:42 PM
Not sure what causes it but I know that it is something that is in the factory programming either ECU based or sensor based.
Old Oct 29, 2008 | 06:48 PM
evo8426's Avatar
are you talking about when it does the throttle hang?
Old Oct 29, 2008 | 06:55 PM
robogast's Avatar
well i tried the clutch thing and it didnt work. It definately does it inbetween second and first.
Old Oct 29, 2008 | 08:03 PM
cosworthevo1133's Avatar
recheck the clearance on the throttle cable
Old Oct 29, 2008 | 08:56 PM
robogast's Avatar
When i installed it i lined it up to the original bolt markings. I dont know why it would have made a change. Im wondering if it might be my tps maybe? or some other sensor?
Old Oct 29, 2008 | 09:38 PM
justboosted02's Avatar
make sure the throttle plate itself isnt sticking
Old Oct 30, 2008 | 01:48 PM
+1 that could be the issue for sure.
Old Oct 30, 2008 | 08:16 PM
robogast's Avatar
Ill be taking my throttle body off tomorrow and replacing the gasket and cleaning the IAC valve and TPS. So ill let you know if i figure anything out.
