HELP.... I have a Problem
Old Oct 31, 2008 | 06:06 PM
milruner's Avatar
Originally Posted by marksae
It sounds like you might have pinched one of the o-rings between the tranny and t-case when you assembled them back together. You gotta be really careful w/ those o-rings. Lube them up w/ oil when you're sliding the t-case back onto the tranny.
well thanks for the help, i just ordered new seals today, wont be in till tuesday put them in, and then hope all is well after that.
MIKE
Old Nov 3, 2008 | 06:46 PM
binky's Avatar
MIKE
Good luck buddy, let us know how it works out!
-Bink
Old Nov 3, 2008 | 09:57 PM
milruner's Avatar
-Bink
cool i let you guys, and gals know tomorrow i get the seals in then putting back together.
MIKE
Old Nov 5, 2008 | 10:49 PM
milruner's Avatar
put the new seals in and it was still a no go my car still leaks tranny fluid into the transfer case someone please help me. I wanna drive my car already.
MIKE
Old Nov 6, 2008 | 05:56 AM
binky's Avatar
MIKE
Hrmmm....That sucks...
I am at work right now, in meetings throughout the day. Let me think about it and I will look at the manual tonight and see what I can come up with...
No worries- we'll get her runnin' !
-Bink
Old Nov 6, 2008 | 06:04 PM
milruner's Avatar
thanks binky, hope you can help me out. the only seal i know that's there is the big oil seal, and the big, and small o-rings only started after changing my diff out in the transfer case, thought seal went bad after changing it, so bought a new one still doing it. got the seal in far, maybe not far enough. please help.
MIKE
Old Nov 6, 2008 | 09:26 PM
milruner's Avatar
bump, maybe someone can help me out.
MIKE
Old Nov 7, 2008 | 04:49 PM
milruner's Avatar
bump, so someone can see this.
MIKE
Old Nov 7, 2008 | 05:51 PM
Duh Panda's Avatar
sucks man i feel your pain...
know clue as to why thatd happen...
why dont you call Shep for some advise or insight.. hes always willing to help
Old Nov 7, 2008 | 06:04 PM
bbyevo8u's Avatar
i hope you find out whats wrong.
offtopic: im getting a knock when i start off in first could this be my tranny? i hope not! anyone
Old Nov 7, 2008 | 06:14 PM
Duh Panda's Avatar
motor mounts?
Old Nov 7, 2008 | 06:25 PM
bbyevo8u's Avatar
i dont want to take it to the dealer cause im moded would i be able to see if its the mount? how will i know for sure?! thanks
John
Old Nov 7, 2008 | 06:26 PM
bbyevo8u's Avatar
the car drives fine once its moving it only knocks when i start from a stop!!
Old Nov 10, 2008 | 04:05 PM
milruner's Avatar
ok back on topic, how far does the oil seal #3 have to go in, maybe that may be my problem, maybe someone has a picture of them putting one in so i can see, maybe mines not back far enough. also don't worry the red circle things i found the picture on the forum, and im just needing to know about the #3 oil seal.
MIKE
Old Nov 10, 2008 | 07:27 PM
binky's Avatar
Hey Mike,
Well...I just wanted to make sure you weren't alone. I had to change my t-case/tranny fluid after my clutch install - and mine did not leak, at least to my knowledge. My car won't go into gear now.....which sucks I haven't driven my evo in a long time either....
Sorry I didn't post sooner, I looked at the manual and I can't figure out why it would be leaking into transfer case.
I was thinking that the part that would be leaking would be on the other side (of the picture you posted) of the t-case where the tranny and t-case meet up. I am also beginning to wonder maybe there is a problem on the tranny (maybe something thats in the way or something missing, maybe something is misaligned) itself that's causing the issue....
Any luck? What have you tried since?
-Bink
