HELP.... I have a Problem
Old Oct 29, 2008 | 08:15 PM
milruner's Avatar
I just re-installed my transmission, and built up Transfer case, back into my 05 MR, and after i got it all done, and back together, i put trans fluid back in to my tranny, and when i finished doing that pulled the filler off on the transfer case, and the tranny fluid started coming out of it, anyone may know what be wrong, maybe the O-ring on the transfer case to the transmission or you guys and gals think its something else. thanks for the help if you all can give me some.
MIKE
Old Oct 29, 2008 | 08:17 PM
cosworthevo1133's Avatar
i really have no idea but i would start with checking the o-ring on the transfer case
Old Oct 29, 2008 | 08:21 PM
milruner's Avatar
well just trying to find out what seals are the ones that let the oil stop from going into the transfer case.
MIKE
Old Oct 29, 2008 | 08:24 PM
EvoHung's Avatar
Take the transfer case back out and inspect it thoroughly. You do not want to put it back the way it is right now. Also, was your transfer case drained completely before putting it back on the tranny?
Old Oct 29, 2008 | 08:39 PM
binky's Avatar
MIKE
Hey Mike-
I just uploaded the Evo VIII manual, its a ZIP file - here's the link:
http://www.megaupload.com/?d=J8R5AN3U
When you download it - check the section called 'Manual Transaxle Overhaul' (GR00005400-22B.pdf). It shows the many different O-Rings and oil seals on the transmission and on the transfer case.
Hope everything works out man.
-Bink
Old Oct 29, 2008 | 08:40 PM
milruner's Avatar
T-case was drained completely, and i guess i get to have fun laying on the concrete again tomorrow pulling the T-case back out. just T-case right not tranny right.
MIKE
Old Oct 29, 2008 | 08:45 PM
binky's Avatar
MIKE
No worries man....I'll be doing the same thing tomorrow too...
-Bink
milruner's Avatar
Originally Posted by binky
Hey Mike-
-Bink
Hey trying to upload it, but how do you use the site.
MIKE
Old Oct 29, 2008 | 08:46 PM
milruner's Avatar
-Bink
why what you break.
MIKE
Old Oct 29, 2008 | 08:47 PM
binky's Avatar
MIKE
Just click the link - and enter the code that is at the top right - a 45 second timer will start and then you can press Download.
-Bink
Old Oct 29, 2008 | 08:49 PM
binky's Avatar
why what you break.
MIKE
I blew my clutch at the drag strip - and have been working on my car now in my spare time after work.
Its ALMOST done...and when I was putting everything back together I broke the boot on my lower ball joint and my outer tie rod ends were shot...So if it wasn't for the suspension I would be done....oh well-
-Bink
Old Oct 29, 2008 | 08:50 PM
EvoHung's Avatar
Yeah, just pull the transfer case. Lets hope its some silly O- ring in the transfer case.
Old Oct 29, 2008 | 10:10 PM
milruner's Avatar
yea i hope so, i want it done already haven't drove my EVO in 3 months.
MIKE
Old Oct 30, 2008 | 05:48 PM
milruner's Avatar
bump anymore info, anyone please.
MIKE
Old Oct 30, 2008 | 07:50 PM
marksae's Avatar
It sounds like you might have pinched one of the o-rings between the tranny and t-case when you assembled them back together. You gotta be really careful w/ those o-rings. Lube them up w/ oil when you're sliding the t-case back onto the tranny.
