Stock evo ix cam lift(asap please)
Old Oct 30, 2008 | 04:43 PM
EVOIXreno's Avatar
What is it for the stockers... I searched and couldn't find it and I googled it as well with no luck...
Thanks
Cory
Old Oct 30, 2008 | 05:26 PM
Skipmaster J's Avatar
Bam!
https://www.evolutionm.net/forums/sh...d.php?t=123216
Factory EVO
Advertised Duration - 260 deg Int / 256 deg Exh
Effective Duration - ___ deg @ 1mm Int / ___ deg @1mm Exh
Lift - 10.0mm Int / 9.5mm Exh
Lobe Centerlines - 109 deg Int /111 deg Exh
LSA - 110 deg
Stock valve springs OK
Old Oct 30, 2008 | 05:41 PM
1NASTYIXMR's Avatar
Originally Posted by Skipmaster J
Bam!
Factory EVO
LSA - 110 deg
Thats for a evo8 hes looking for a evo9.
Are they different?
Old Oct 30, 2008 | 05:48 PM
shunderwunder's Avatar
They have the same exhaust cams, btu the intake cam is diffrent. not sure what it is or if it's the same spec but made to work with the MIVEC.
reliablefr
18
Aug 30, 2012 11:46 PM
