massive sputtering (i've searched)
Old Nov 20, 2008 | 10:30 AM
MR Turco's Avatar
yeah definitely colder plugs with that turbo. Also i wouldn't touch the iridium tip with a gap tool if you are checking gap. It is pretty delicate and should only be gaped with a gap tool specifically for iridiums.
Old Nov 20, 2008 | 11:30 AM
Mellon Racing's Avatar
Originally Posted by filter
ok ive installed the new plugs and same issue comes up at 4500 rpms about 14psi.
i left you a msg mellon. im tearing down all the intercooler connections and re doing them to see if we have a boost leak.
hmm...spark plug wire, coils etc...
send me a log of it in action
Old Nov 20, 2008 | 11:34 AM
MR Turco's Avatar
is it possible the turbo is surging due to the low boost
Old Nov 20, 2008 | 11:39 AM
it ran great when I tuned it, so something has changed, that's why I suspected the spark plugs.
Old Nov 20, 2008 | 12:07 PM
I spoke with zane a moment ago, the plugs are at .023 currently and it sputters at 14psi (low as he can go) or higher boost too but if he drives it at part throttle it's fine and he can get past 4500 where the problem begins.
He's going to check the hoses visually (doesn't have a boost leak tester kit yet) and send me a low boost log so I can see what it looks like while it's happening. My hunch is that he has a bad plug wire or coil...sounds like an ignition problem the way he described it to me.
Old Nov 20, 2008 | 12:21 PM
haseeb's Avatar
i had the same problem after i changed my plugs .i ve ngk iridium num 9 plugs but b4 i had num 8 plugs and it was fine .plz suggest wat to do.
Old Nov 20, 2008 | 12:22 PM
MR Turco's Avatar
this probably isn't the solution but make sure the FPR vacuum line isn't pinched. I doubt it is since it is making it to 14psi but it isn't tough to check.
Old Nov 20, 2008 | 12:23 PM
9 is a very cold plug, I didn't go to those until I get into the 550-600awhp area and installed the coil on plug setup to make sure they stay clean and don't foul out quickly.
Old Nov 20, 2008 | 12:26 PM
that's a good suggestion
Old Nov 20, 2008 | 12:28 PM
haseeb's Avatar
im at 30 psi boost wid t4z88hta and stage 4 2.3l long block .wat do u say as this hapens at low boost also ?should i go back to num 8 plugs ?or it cud be somthing else also ,btw it doesnt hapen at a cirtain rpm ,it hapens at wot in 3rd and 4rth gear only.
Old Nov 20, 2008 | 12:31 PM
Originally Posted by haseeb
im at 30 psi boost wid t4z88hta and stage 4 2.3l long block .wat do u say as this hapens at low boost also ?should i go back to num 8 plugs ?or it cud be somthing else also ,btw it does hapen at a cirtain rpm ,it hapens when eve i floor the paddlf in 3rd and 4rth gear .
I'd give you he same advice as filter...gap the plugs to .022 carefully (if you have stock ignition) and see if that fixes it. If it does not, install new plugs, the 9's might be TOO cold and fouling out quickly (don't know your AFR etc..) so try the 8's. If that doesn't work you're in the same boat with filter, could be wires/coils or tune(too rich, not enough timing etc...)
Old Nov 20, 2008 | 12:35 PM
haseeb's Avatar
ive got hks twin power also .il go back to num 8 plugs and let u know .ny waz thanx for ur advice.
Old Nov 20, 2008 | 12:45 PM
Peteypab2133's Avatar
I was having basically the same problem. Car sounded like a subaru and was breaking up badly. I changed my plugs twice, and finally found that my magnacore wires were going bad.
I run the IFLR7h plugs from NGK.. they seem to do fine.
Did not see it in any of the posts, but make sure you are running 9 plugs and not 8 plugs. If you dont know already they are shorter than 9 plugs and dont work very well.
And as others have said, just because advanced or someone tells you they are okay, dont listen to them, they always try to sell 9 owners 8 plugs !!!
Old Nov 20, 2008 | 12:48 PM
I run the stock wires for what it's worth...haven't found a reason to replace them yet.
Old Nov 20, 2008 | 12:57 PM
Lumpskie's Avatar
I get the same sputtering problem, but only when it is cold out and the car is not fully warmed up. I'm running a stock turbo and it usually happens during the transition from vacuum to boost. I changed my plugs out and it still happens. Just another data point for those of you who care.
