Can I run 1000cc injectors on stock ecu? Id like to run E-85 and make about 450-500 hp daily
Mods:
SLS 256 Borgwarner turbo kit and IC kit
eagle crank, rods, wiesco pistons 264 cams
255 walbro soon to have double pump kit..
alcohol injection
650cc injectors
So how many ppl run 1000cc injectors? and does it idle well..?
Mods:
alcohol injection
650cc injectors
you sure can, I run 1000cc PTE on E85. Make sure your tuner can scale them correctly.
Yep you can, I run the FIC 1050CCs on stock ECU. It idles pretty smooth even with cams.
1000's are not an issue on stock ecu as long as you have a descent tuner
1000's, 1200's etc no issues.
Even the new FIC Blue 1450cc's seem to work pretty well on the stock ecu
Quote:
Originally Posted by bboypuertoroc
Talk to Mellon, he'll square you away.
thanks guys .. now to run E85 can I run an IN-Line fuel pump or should it be 2 intank pumps?
1000's on E-85 is like running 650's.. LOL
We have run 1200's and made 460hp on stock ecu, stock IX turbo on E-85 w/o any issues!!
I run pte 1000's on e85 on the stock turbo and a single walbro, made 386 whp and 466 ft lbs on a mustang dyno.
