Help Head Removal
Old Nov 2, 2008 | 02:32 PM
EvoFlash's Avatar
Help Head Removal
I think I got all the bolts off,headstuds off but can't get it off. Is there anything hidden I'm missing?
Old Nov 2, 2008 | 02:35 PM
robjeff25's Avatar
did u get that banjo bolt on the back lower left part as you are looking at the engine from the front?
Old Nov 2, 2008 | 02:38 PM
wevo1985's Avatar
their is a small 10mil bolt under the themostat housing that you might be missing. it holds the coolant line to the head. check that.
Old Nov 2, 2008 | 02:46 PM
Johnboy1065's Avatar
are you taking the head off with the intake manifold still attached? if so there is a bracket on the bottom of the intake manifold that bolts it to the block.
Old Nov 2, 2008 | 03:57 PM
EvoFlash's Avatar
I was but I am removing the intake now first then on to bracket thanks for help. Do I have to do anything with the timing belt right now to remove the head? Can I cut it and just replace it when it comes time to?
Old Nov 2, 2008 | 04:05 PM
wevo1985's Avatar
i just take the cam gear off. but im using mine again cause its only got 5k on it and its an hks. if your not using it again you can cut it to save time. remeber to set all the timing before you put it all back together
Old Nov 2, 2008 | 04:21 PM
EvoFlash's Avatar
sounds good thanks.
Old Nov 2, 2008 | 04:24 PM
scorke's Avatar
http://video.google.com/videoplay?do...13355787&hl=en
I recommend shotgun.
Scorke
Old Nov 2, 2008 | 04:28 PM
wevo1985's Avatar
o man!!
Old Nov 2, 2008 | 05:08 PM
biggie5252's Avatar
Old Nov 2, 2008 | 05:46 PM
EvoFlash's Avatar
Lol not cool got to start somewhere lol.
Old Nov 2, 2008 | 05:54 PM
1d10t's Avatar
Old Nov 3, 2008 | 03:37 PM
EvoFlash's Avatar
I got it off simple after the 2 bolts off the bracket under intake mani.
Old Nov 3, 2008 | 03:45 PM
wevo1985's Avatar
yes it should just come right off.
Old Nov 3, 2008 | 03:47 PM
SyZyGy1394's Avatar
Originally Posted by scorke
