What flywheel is this? Pic inside
Nope! Our Prolite has areas around the outer perimeter that are milled completely through the flywheel where you can see that this one is not milled that way. Looks like maybe a 10lb Prostreet or similar (not to be confused with ACT Prolite or Streetlite). It is much thinner behind the clutch surface than either of ours.
Can these be resurfaced? If so what is the min thickness allowed after turning?
Not sure if it's a Pro Street.. I found a pic of one.. and they are way different.
Also how heavy is the stock evo 8 flywheel?
Pro Street 10.45 lb flywheel
