epm dump noise
Old Nov 8, 2008 | 07:17 AM
griffeyr's Avatar
epm dump noise
We put the epm 02 dump on the red, and it makes thing sorta pinging noise at idle....They said it was the flapper valve on the wastegate rattling, and the reason it was loud was b/c of the dump tube...Anyone else here this noise???
Old Nov 8, 2008 | 08:38 AM
TouringBubble's Avatar
I have no pinging noise ... I've never heard one on the cars I've tuned either. You didn't re-use the stock gasket did you?
Old Nov 8, 2008 | 08:47 AM
sparky's Avatar
Try shortening the length of the actuator rod, which you can adjust by rotating the turnbuckle on the threaded end. This should keep the flapper valve from bouncing up off the seat. You probably have no preload on the wastegate. Set it to about 14 PSI or higher.
Old Nov 8, 2008 | 09:38 AM
MasterNater's Avatar
+1
Old Nov 8, 2008 | 09:41 AM
AWD Motorsports's Avatar
Make sure they did not reuse the stock gasket..
Old Nov 8, 2008 | 09:50 AM
griffeyr's Avatar
We put it back on the lift, stuffed the dump tube, and the noise went away
Old Nov 8, 2008 | 09:51 AM
Stuffed the dump tube??? meaning blocked the tube off?? if the air is exhaust coming out of the dump at idle.. you have a 99.99% chance they reused the stock gasket which cannot work..
Old Nov 8, 2008 | 11:21 AM
FastAzzEvo's Avatar
agreed take of stock gasket and check preload on wga,
there shouldn't be any air coming out of dump tube at idle
Old Nov 8, 2008 | 06:59 PM
sparky's Avatar
Yeah, if you're getting exhaust flow out the dump tube at idle either the flapper is lifting up off the seat due to low WG preload level(spring pressure), or as Mike says, the installation of the stock gasket allows turbine exit gas flow to crossover into the dump tube. One or the other.
Old Nov 9, 2008 | 04:15 PM
griffeyr's Avatar
if its the wg, how do i fix that???
daechul2da
Nov 3, 2009 01:34 AM
SixOneNine
Jul 10, 2009 12:02 AM
Bizo2
Apr 7, 2009 03:30 AM
6-speed
19
Mar 21, 2009 04:40 AM
EvoDom
23
Feb 4, 2009 08:55 PM
