Quick Q on mechanical O2 fix
Old Nov 8, 2008 | 09:08 PM
DvlInDskyz's Avatar
Is it a good idea to clean the O2 sensor prior to installing it in the mechanical O2 fix found on this site? Has anyone done this and what is the best thing (spray or chemical) to clean it with if so?
Old Nov 8, 2008 | 09:09 PM
EvoDan2004's Avatar
do not spray the o2 with anything.
if anything use a clean paper towel and just clean it off. then use LIGHT pressure air to lightly blow it off. your mouth will do just fine as well. do not touch the o2 with your fingers.
Old Nov 8, 2008 | 09:10 PM
1d10t's Avatar
spray some brake clean on a rag and clean the tip. If there were no issues or codes thrown you should be ok. I wouldnt spray any chemicals on the sensor.
Old Nov 8, 2008 | 09:12 PM
EvoDan2004's Avatar
hum. brake clean is a chemical.
do not spray nothing on the o2. not even spit. just use a rag or paper towel and wipe it off. then blow some air on it but not high pressure.
Old Nov 8, 2008 | 09:16 PM
1d10t's Avatar
I dont think brake clean on a rag will harm the electrodes inside the o2. A small dose of brake clean will break up carbon that may be covering the holes on the tip. If there are no issues with the sensor before, just put it back in.
Old Nov 8, 2008 | 09:18 PM
EvoDan2004's Avatar
i mainly agree but at the same time a good sensor is a good sensor. a new one can run up a nice bill so why risk it.
the holes sometimes get clogged but i never had a issue when just wiping it off and blowing the rest when done.
DvlInDskyz's Avatar
ok. No chem will be used. I'll just wipe it and blow it off with a little air. Thanks for the info!
nisils14
Feb 14, 2017 07:50 AM
BluesunsXIV
Jun 27, 2009 06:34 AM
btownsoccer22
20
Jan 15, 2009 07:37 PM
fastassfourdoor
Mar 20, 2007 10:25 AM
Cyloc
Feb 19, 2007 04:57 PM
