What oil pressure is everyone reading?
Old Nov 12, 2008 | 06:54 AM
Chabada15's Avatar
anyone with an oil pressure gauge with the sensor mounted into a sandwich adapter whats the max oil pressure everyone's seeing?
Old Nov 12, 2008 | 07:07 AM
sub7's Avatar
About 100psi during cold start and 21psi idling
Old Nov 12, 2008 | 08:11 AM
Yorl8's Avatar
More or less the same. A bit higher at idle when the engine's warm. Around 25
Old Nov 12, 2008 | 08:30 AM
Chabada15's Avatar
ok good cause thats what mine is at, and a guy i kno said that was high, i mentioned it had been liek that since i put the gauge in and he said the most i should see is 40psi....im gunna go call him an idiot now, thanks everybody
Old Nov 12, 2008 | 08:33 AM
Ph3n1x's Avatar
Old Nov 12, 2008 | 03:28 PM
Jay644's Avatar
Mine hits about 140-145psi at redline. Idle on a cold start is around 95-100, then 15-25 when warm.
Old Jun 1, 2009 | 02:31 PM
peter*g's Avatar
That's really high. Where are you reading from? What RPM is that?
Old Jun 1, 2009 | 02:38 PM
Macaroni's Avatar
Wow mine is really low compared to you guys. I have mine reading from the head and idle is like 11, cruising is around 35, and redline is maybe 40.
Old Jun 1, 2009 | 02:52 PM
Walt's Avatar
Hey Macaroni i think there might be something wrong with your gauge. You should get that checked out cause im running about same pressures as others in thread
Old Jun 1, 2009 | 03:15 PM
Macaroni's Avatar
Maybe my sensor is clogged... It is pretty old lol. I just hope its the gauge and not low oil pressure
Old Jun 1, 2009 | 03:23 PM
UT_Evo's Avatar
That's about what mine was reading too, dunno where it was mounted to, pretty sure it was the head. Only diff was that I was at about 8 at idle.
Old Jun 1, 2009 | 03:30 PM
Macaroni's Avatar
Look behind the cam angle sensor. There are 2 plugs in the head. You can use either of those to run your oil psi. It will more than likely be there.
Old Jun 1, 2009 | 03:43 PM
UT_Evo's Avatar
That directed at me?
I have no way of checking, the car is long gone. I think someone in WY has it now
Old Jun 1, 2009 | 04:06 PM
Macaroni's Avatar
Oh yea that was to you lol. Go hunt it down and check!
Old Jun 1, 2009 | 04:12 PM
peter*g's Avatar
If you're reading oil off of the top of the head, your numbers are going to be WAY lower than those of us reading off of the galleys by the filter. You're probably alright.
