What oil pressure is everyone reading?
Old Jun 1, 2009 | 05:18 PM
Macaroni's Avatar
I have a fitting to where I can run it down by the filter. I might put it down there to see what it's reading then. Even if it's perfectly fine, I don't like seeing it that low.
Old Jun 2, 2009 | 08:32 AM
Chabada15's Avatar
down at the filter the lowest i read is 16psi at idle but on my gauge its 100% based on RPM, there relative, as RPM's increase so does the pressure, before oil is at operating temp (about 180*) i can get pressure readings well into the 100's, its good for the track though cause if it was to suddenly drop i would immediately notice
Old Jun 2, 2009 | 09:21 AM
Davo's Avatar
i think oil bodies should also be stated
Amsoil 10W-30
Start from cold 76psi
warmed at idle is 16psi
ams remote line, stri gauge
Old Jun 2, 2009 | 10:13 AM
Chabada15's Avatar
i used to use amsoil, then royal purple...i have an oil temp gauge and the one that stayed the coolest under the most beatings was mobil1 funny enough, i still run amsoil in the diffs and tranny
Old Jun 2, 2009 | 12:33 PM
darkwolf's Avatar
80-100 at cold start, when warm and idling ~20-25 - using Mobil 1 10w30.
Old Jun 2, 2009 | 01:23 PM
crcain's Avatar
My sensor is on the oil filter housing.
Read about 20 psi at idle and a bit over 100 psi at high rpm.
Old Jun 2, 2009 | 02:29 PM
Macaroni's Avatar
Next oil change I'm changing my sensor location.
Old Jun 2, 2009 | 07:04 PM
Jeff_Jeske's Avatar
^ You don't need to wait for an oil change.... most of the oil will be in the pan only a very small amount would be at that plug.
Old Jun 2, 2009 | 07:35 PM
Macaroni's Avatar
Yay! I will do that tomorrow then!
Old Jun 3, 2009 | 02:28 AM
barneyb's Avatar
There is spring loaded thingy in the head that dumps oil if the pressure is too high. I guess Mitsu doesn't want a lot of oil pressure in the head.
Old Jun 3, 2009 | 05:36 AM
Tbtalon94's Avatar
Pro-sport gauge here, sensor in the oil filter location
cold start is up around 85-95psi, warmed up idle is around 18-22.
gasolinebaptism
Mar 12, 2015 08:00 PM
cayman evo
Sep 30, 2006 03:06 PM
KILTERMAN
May 31, 2005 11:59 AM
badhabit90
Mar 1, 2005 08:58 AM
4G63>OOOO
Dec 2, 2003 12:09 PM
