oil leak
Old Nov 15, 2008 | 08:26 AM
shawn360h's Avatar
oil leak
I was doing an oil change 2 days ago and i noticed the whole oil pan has a thin coating of oil on it. I look around some more and seen that the back of the block has the same problem. From what i can see it was coming from my head gasket. I put ARP headstuds in about 6000 miles ago and when i retourqed the head i tourqed it to the factory specs not knowing you have to do it differently with headstuds. I called ARP and got the correct torque specs and i went to retighten them and they were more then 85 ft/lb which is what they are supposed to be. my question is could me over tightening my bolts cause the headgasket to leak or do i have another problem? Should i get new studs to replace the ones i have in there now when i replace the head gasket? thanx for the input
Old Nov 15, 2008 | 08:50 AM
1d10t's Avatar
Are u sure that you didnt pinch the valve cover gasket?
Old Nov 15, 2008 | 10:10 AM
shawn360h's Avatar
yes because there is no oil on my intake manifold which it would be most likely to get on first.
Old Nov 15, 2008 | 10:19 AM
lillev23's Avatar
did you change the headgasket?
Old Nov 15, 2008 | 11:43 AM
shawn360h's Avatar
when i put the head studs in? yes i put a new head gasket, valve cover gasket, and cam oil seals in.
Old Nov 15, 2008 | 08:53 PM
shawn360h's Avatar
bump
Old Nov 15, 2008 | 10:21 PM
psphinx81's Avatar
what kind of headgasket did u use?
Old Nov 16, 2008 | 07:43 AM
shawn360h's Avatar
The head gasket and valve cover gasket are both straight from mitsubishi
Old Nov 16, 2008 | 08:05 AM
gsr0801's Avatar
changing the gasket if it wasn't damage was a waste. I use my stock head gasket after I change my stud I running 30psi daily driven. But your gasket sounds like its shot.
Old Nov 16, 2008 | 08:13 AM
boosted2x2's Avatar
check your oil pressure switch. had same problem and that was it.
Old Nov 16, 2008 | 01:31 PM
shawn360h's Avatar
its not the pressure switch cause there is oil well above it and there is no drips coming off the sensor. I picked up a new head gasket yesterday and im gonna change it during the spring and i can ride my bike. Do you think its a good idea to get new studs since i over torqued them?
DanDan1320
Oct 10, 2013 06:57 AM
memphis raynes
Jul 7, 2012 12:44 PM
AcePitcher11
Jan 19, 2010 12:52 PM
funkamedics
May 25, 2008 06:30 PM
jid2
Northwest Region
12
Mar 25, 2008 09:45 AM
