Exhaust Manifold ?'s
Old Nov 26, 2008 | 10:15 AM
Steve93Talon's Avatar
PB blaster, and break the bolts loose while the engine's still warm. I always replace the nuts and bolts every time I take the turbo/manifold apart and use high temp anti-seize. For the bottom nuts, a 1/4 drive ratchet works great, gives you alot more room to work.
Old Nov 26, 2008 | 12:02 PM
Evoryder's Avatar
^ oh! Definitely let the bolts soak in pb blaster overnight.
Old Nov 27, 2008 | 08:45 PM
evoprime1's Avatar
i just did my 9 turbo swap and i used liquid wrench and warmed up the mani a bit and everything came apart like a charm
Old Nov 27, 2008 | 08:55 PM
Peteypab2133's Avatar
Originally Posted by jdm4g63tgalant
Pb blaster and breaker bar...
as far as the bottom nuts on the mani...you'll have fun with that.
use a 1/4 drive with a short swivel on the socket. should get them with no issue at all.
And PB the hell out of all of them for about 10 minutes before you start playing. Dont break anything, or strip.
have fun!
