tranny fluid change
Old Nov 27, 2008 | 02:43 AM
MitsuEvo05's Avatar
tranny fluid change
when i shift into 3rd gear its notchy for at least the first 15 minutes so some people suggest changing the tranny fluid, if you have any idea what other problem it could be let me know.
i plan to purchase off of Modern Automotive Performance and i was wondering if anyone had any kind of coupon code for my purchase thanks!
Old Nov 27, 2008 | 08:23 AM
cfdfireman1's Avatar
I use the redline shockproof light with good results. But you should search.
Old Nov 27, 2008 | 12:36 PM
detroit pistins's Avatar
i have the same issue and the Penzoil Syncromesh from autozone helped alot. but it doesn;t last as much as the oem stuff, iam planning on using the penzoil stuff for 5-10k miles thens witch t back to the oem.
Old Nov 27, 2008 | 12:43 PM
apagan01's Avatar
we carry AMSOIL MTG lots of customers have had great sucess with it,,, if you need any we have them ready to ship
Old Nov 27, 2008 | 12:48 PM
Smike's Avatar
Like cfd said - search.
I have been running the Amsoil MTG for 50-60k (multiple changes).
Old Nov 27, 2008 | 12:54 PM
Protostar1's Avatar
I use redline and I have noticed a slight decrease in notchiness, but the Evo gearbox is pretty notchy until the fluid is heated. Once that happens my gearbox is slick as ****. Redline or AMSoil are the two best from what I have read. I will be switching to all AMSoil products for next season to see if it lives up to the hype.
Old Nov 27, 2008 | 03:14 PM
chaotichoax's Avatar
your fluid has to warm up...if it goes away you are fine
Old Nov 27, 2008 | 04:06 PM
FQ-300's Avatar
Amsoil, period.
I'm using Amsoil fluids throughout my car and I must say it has lived up to and beyond the hype. Everything "feels" awesome. From the engine to the transmission, I feel the car performing at the highest level with the added security of knowing that all the components are fully protected as well.
Zero issues.
Old Nov 28, 2008 | 04:23 AM
Gary@MellonRacing's Avatar
i used 3 quarts of mt90 redline as recommened by team rip
Old Nov 28, 2008 | 04:36 AM
BlueEvo61106's Avatar
yea it is just the cold man! that's our tranny's in the cold. My evo 8 does it as well. If you want to change your tranny fluid I would go with BG Syncroshift II for tranny fluid and Diaqueen for XCase and Differential!! No issues with those.....
Old Nov 28, 2008 | 09:32 AM
Oil Doc's Avatar
I have switched hundreds of EVOm Members over to AMSOIL MTG with great results.
For under $40.00, it is well worth it.. Especially if you compare it to the Cost of OEM Fluids
Old Nov 28, 2008 | 07:23 PM
Sorry MitsuEvo05 no coupon code here but just another oil suggestion.........Just did all 3 today...........BG Syncro II in tranny / Redline Shock Proof in front diff & Redline 75/90 in rear diff........There are many choices in brands (Synthetic / Viscosity's etc)..........Saved a few bucks doing it myself ..........Best regards to all........MinusPre
Old Nov 28, 2008 | 07:30 PM
headrec's Avatar
I just purchased some MT90 after reading a lot of recommendations from people one being John Shepard. Hopefully it will help out.
GsrJake
Dec 15, 2012 04:48 PM
rcheung
Aug 3, 2010 09:02 AM
cec12789
14
Oct 6, 2009 07:36 PM
orangeorphan
Jun 4, 2009 07:33 PM
civicevo380
Northeast Region
Jan 11, 2007 08:40 PM
