First Tranny Fluid Change Help
Old Jun 4, 2009 | 04:26 PM
orangeorphan's Avatar
So I'm about to change the tranny fluid with synchroshift and am wondering If I need to change the transfer case fluids as well? If so what type of fluid does it use?
Old Jun 4, 2009 | 04:33 PM
Tnnrx7's Avatar
http://www.evogarage.net/home/?tag=fluid
Old Jun 4, 2009 | 04:41 PM
vvhiteix's Avatar
the diaqueen....
Old Jun 4, 2009 | 04:45 PM
AKEVOIX's Avatar
use stock mitsu dia-queen fluid in x-case. and i also used bg in my tranny.
Old Jun 4, 2009 | 05:26 PM
TyeVO's Avatar
Transfer Case And Rear Differential use:
One can will give you 2-3 fluid changes
http://www.extremepsi.com/store/cust...at=1133&page=1
Transmission Use:
One can is one fluid exchange
Get a pump pump the fluid till it starts dripping out of the fill hole then put the plug in and walla! Do that for all 3
BE SURE THE CAR IS 100% LEVEL
Old Jun 4, 2009 | 05:33 PM
apagan01's Avatar
TRANNY
TC and REAR DIFF
check these threads out
https://www.evolutionm.net/forums/ev...our-input.html
https://www.evolutionm.net/forums/ev...ease-read.html
Old Jun 4, 2009 | 05:56 PM
3SgteGuru's Avatar
Yes I used what Apagan01 sells and its great (bought it from Apagan01 too, Highly recommend). GL5 in the LSDs ( rear diff and Transfer). And GL4 in the Transmission.
Old Jun 4, 2009 | 07:33 PM
chaotichoax's Avatar
search
closed...
GsrJake
Dec 15, 2012 04:48 PM
evolution5690
Mar 12, 2011 05:26 AM
cec12789
14
Oct 6, 2009 07:36 PM
rcboosted
15
Aug 23, 2009 05:49 AM
04lancerEsGuy
Lancer Tranny/Drivetrain Tech
38
Apr 1, 2008 04:39 PM
