Chromoly Flywheel
Hi !
I'm running a pretty stock Evo 7 (CT9A) with mild standard intake and outake mods. I'm replacing my clutch with the stock OEM mitsubishi clutch and found that the flywheel has got scratches and needs replacing. Should I with the original mitsubishi flywheel or can it be replaced with anaftermarket lightweight (4.3kg - 4.7kg) chromoly flywheel from xtreme http://www.tweakit.net
It says in the site that it may affect idle and lower rpm running. This aftermarket part is cheaper than the OEM mitsu parts.
Can anybody shed some lights on this issue. Thanks guys.
