Fp Red
Old Nov 28, 2008 | 07:10 PM
9sec9's Avatar
Controlling the boost: Look for wastegate pressure, (May be too high if you're trying to run low boost)
Check your O2 housing and downpipe for restrictions. You may be surprised.
Port the turbine side of the turbo if you're trying to run above 30 psi. Even if you're not, it should get ported. There's an answer to every problem, just eliminate each obstacle, one at a time.
Old Nov 28, 2008 | 09:50 PM
Shacochis06's Avatar
lol i wana know who told you this....just look how hard 9sec9 pushes this lil turbo....i think his results speak for themselves with this turbo
FP FTW
Old Nov 28, 2008 | 11:52 PM
backcountryGSX's Avatar
I wont say names or point fingers, all I'll say is the person who told me this is quite knowledgeable about turbos. That's why I took it seriously. Maybe I'll wait a few months to buy a red to make sure no one has any problems.
What psi is the majority of red owners running their turbos at on pump gas?
Old Nov 29, 2008 | 06:28 AM
Mellon Racing's Avatar
my customers are running anywhere from 23-30psi
Old Nov 29, 2008 | 11:55 AM
CBRD's Avatar
Originally Posted by beemerfreak
From what I've read about the CBRD BBK turbos someone was having boost creep problems at lower rpms. So CBRD had him port his exhaust manifold and that did the job.
this is not true at all... there have been no issues of creep with the production versions of the BBK...
there was a car with a 2.3 using an electronic controller, with upgraded actuator (with 4 turns of preload), and STOCK turbine and housing with some creep...
that was in the test phases with a clipped stock turbine etc...
porting and polishing is an option to our clients as the portwork is awesome.....
our turbo and the red are great turbos, they just fit a different niche.
cb
Old Nov 29, 2008 | 12:01 PM
Cali2MDevo8's Avatar
Registered User
No boost creep with my BBK........
Old Nov 29, 2008 | 01:01 PM
^^yea cos the red is more of a high boost turbo...im sure hes only tuned for like 23psi so no wonder hes seeing boost creep....i dont know why people want to run 21-24psi with the red...dont make sense
Old Nov 29, 2008 | 01:02 PM
I think some of the road course guys prefer 23psi and more timing to keep the heat soak in check, otherwise I suggest 25psi minimum.
Old Nov 29, 2008 | 01:07 PM
also your running like what 23psi? correct?...thats waht the bbk was designed for
Old Nov 29, 2008 | 03:49 PM
sparky's Avatar
Originally Posted by gsr0801
SO what would you recommend if you can't control your boost even with a manuel boost controller and every supporting mods to make this turbo works fail. I have that problem and can't even tune my car.
Will you put up your complete modlist?
Old Nov 29, 2008 | 04:49 PM
Zeus's Avatar
Sounds like someone has (or will soon have) something to sell you
Sorry to get pissy, but about all the questions one could ever have about the Red have answers already posted in other threads. People fail to look through the threads with the best info... usually the LONG threads!
There are no threads of failed Red turbos scattered about...
BTW this is not a shot at the OP, but at all the people who "hear" something and fail to search the forum for the answers. If you got Einstein and Newton in the same room, I'm sure tempers would fly there too. Just because someone is knowledgeable, does not mean their particular opinion is correct. I disagree with knowledgeable people, sometimes I prove right, sometimes wrong. However, I don't usually go against a majority experience contrary to my opinion.
Old Nov 29, 2008 | 04:58 PM
Zeus's Avatar
PM me and I'll see if I can help you...
Old Nov 29, 2008 | 05:37 PM
Evolution IVGSR's Avatar
I'm am waiting to get my Red soon... Haven't heard anything but good about these turbos from everyone
Old Nov 30, 2008 | 09:56 AM
gsr0801's Avatar
Exclamation
Turbo XS intercooler
HKS 272 cams
Power Agency Exhaust
DC Sport Downpipe
780 CC Injectors
Injec intake
255 fuel pump
Megan 02
FP Red Turbo
Fuego
For Sale - Part Outs
Oct 18, 2016 10:12 PM
Freddy302
Oct 11, 2016 05:55 PM
Seenoevol
Jan 28, 2015 05:14 AM
03BoostedVIII
Northwest Region
Jan 30, 2011 03:37 PM
Kaymo
Lancer Aftermarket Forced Induction Tech
283
May 3, 2005 10:23 AM
