car hesitates/backfires under acceleration
Old Nov 30, 2008 | 07:30 AM
jorge mr's Avatar
hey guys been doing a search for awhile and still cant figure it out!
during the summer my car runs great no problems, but its getting cold again so this problem keeps happening. at wide open throttle during 3rd or 4th gear, around 4500 rpms the car will back fire or hesitate while my foots on the gas pedal and whenever this happens, its a pretty aggressive hesitation!!
sounds weird but it only happens in the winter time noticed it when i installed the greddy profec b spec 2. switched it out for an ams mbc and its still doing it
my car is an 06 mr.
turbo back, fmic, lower ic pipe, mbc, k&n filter all by ams
any help would be appreciated cause this sucks!!!
Old Nov 30, 2008 | 07:34 AM
Evoryder's Avatar
1. is your car tuned?
2. changed your plugs or even checked them?
3. Clean your maf sensor.
4. I don't think you REALLY searched.
Old Nov 30, 2008 | 07:36 AM
Mellon Racing's Avatar
sounds like he's hitting fuel cut, needs to be tuned
Old Nov 30, 2008 | 07:44 AM
wevo1985's Avatar
+1, i had that problem with my black evo, cool air and anything above 20psi will do this
Old Nov 30, 2008 | 07:46 AM
Sharkbite2000's Avatar
Check your plugs first and then your boost
Old Nov 30, 2008 | 07:58 AM
cthcky5's Avatar
listen to these guys. they hit the nail on the head
Old Nov 30, 2008 | 08:01 AM
gsrboi80's Avatar
Probably seeing a tad more boost cause of the colder air.
Has the car been tuned cause if not theres you problem. PM the third guy in this thread
Old Nov 30, 2008 | 08:17 AM
jorge mr's Avatar
plugs were changed 6k miles ago, my boost level is at 23 psi then tapering off to 20 yesterday i did see 24 no too much difference just a little, my car has had a miled tune as well as he has logged my car while doin a small tune cause this occured with him in he car the reason for the miled tune over an aggersive one was for the fact that my wideband has not yet shown up cant really do a aggresive tune without a wideband apprecitae all advise and am hoping my wideband shows up to see if this will fix the problem
Old Nov 30, 2008 | 01:30 PM
braizedtofu's Avatar
wow, what kind of tuner is tuning your car without a wideband? Sorry its annoyign me that you keep saying miled... its mild.... like mild salsa... anyway post some logs, if you are knocking hardcore its possible your car will pull back timing or fuelcut. If you can get to 4500 and your boost sounds okay then most likely your turbo is okay and it is your tune. imho wait till you get the wideband you cheap/impatient/lazy ***, and redo the tune Why risk gaining a few hp at the risk of blowing/wearing things out
Old Nov 30, 2008 | 01:35 PM
apagan01's Avatar
i was going to say Mellon, maybe lean condition because when cold he is over boosting pulling timming.
agreed need to be re-tunned
Old Nov 30, 2008 | 01:38 PM
Evoryder's Avatar
i was thinking boost cut also. Back to: 1. are you tuned? Looks like not very well.
With the cooler ambient temps your maf is passing more air through it just like upping the boost would create more airflow.
To combat this issue your tuner has to tweak the boost limit area or you will have to lower the boost 1 turn down to stay within your current *boost limit* range.
Contact mellon for further assistance for questions vs creating threads that have been made before.
xelloss
Outlander Sport
11
Nov 21, 2016 09:50 PM
blaze_125
Lancer Troubleshooting
Dec 2, 2011 09:52 AM
05lanceralliart
Apr 2, 2009 07:01 PM
BlackTypeS
12
Apr 12, 2007 06:16 PM
ct9a gsr
21
Mar 21, 2005 11:44 AM
