all around turbo.
Old Dec 2, 2008 | 12:13 AM
4g63smokinall4s's Avatar
Originally Posted by S2kracka
Cbrd Bbk
If you like the stocker as you stated..
then yes the CBRD BBK would def be the way to go think makes awesome power with great power curve! DO IT!
https://www.evolutionm.net/forums/sh...d.php?t=379854
https://www.evolutionm.net/forums/sh...d.php?t=380104
Old Dec 2, 2008 | 12:30 AM
WickedIXMR's Avatar
Originally Posted by Duh Panda
lol.. whyre you gooing to pay 1grand+ for a similar "stock" turbo that has been upgraded a bit...
why not just get somethin diff
jus doesnt make any sense to me
What doesnt make any sense to me is why you are saying for him to get a gt30r when that turbo has much more lag then stock when he could get a FP red which makes more power and a tiny bit more lag then stock. FP red is capable of making over 400whp on pump and over 500whp on race and has been proven to be capable of running 9's (which a 30r has yet to do) and it also retains the stock manifold and o2 housing as well as oil and coolant lines.
Old Dec 2, 2008 | 04:02 AM
MitsoKid's Avatar
I'm looking for the same thing, but a 35R is a horrible choice.. I like the stocky, but I've heard that the 3076 with a .86 A/R does really well.. Plus I really like this kit
http://www.jscspeed.com/evo/turbo/atp_stealth.htm
too bad i just dumped a load of money into an Exedy HD Twin, StopTech Fronts, Brembo GT rears and all stainless lines, other wise I would shoot for an FR RED
Old Dec 2, 2008 | 04:13 AM
Kemist's Avatar
+1
Old Dec 2, 2008 | 04:41 AM
grillpt's Avatar
30R is dead...
Go with the BBK!!!
Old Dec 2, 2008 | 05:04 AM
supersal's Avatar
A 3076 will hit full boost at about 4200rpm in a single scroll T3 .63 hotside off boost its a bit soft and not as punchy as the stock frame turbos...
The best spoolin Turbo in the ATP kit is a GT3071R .63 hotside - it is capable of 450HP on the stock block stock ecu setup and doesn't taper like the stock hotside at high rpm.
hope that info helps you with your choice...
If I was staying stock block and could afford it I woul probably go FP Red with all the bolt-ons for 500HP.
Old Dec 2, 2008 | 05:37 AM
CBRD's Avatar
there is no reason to go 3071R when you can stay stock housing...
the 30R and 35R are no fun on standard pump gas in my opinion... sure they will make good "peak" hp, but barely any torque... the car may feel fast over 5000 rpm, but ultimately on the street it will be slower then a properly built bolt on car or a car with stock housing.
if you REALLY want to go to a t3 style turbo kit or the sort, go with a stage 3 50 trim, or a variation of it.
thats just my two cents.
cb
Old Dec 2, 2008 | 05:52 AM
supersal's Avatar
Agreed...
I take it the stock frame BBK would outperform the GT3071R on pump gas then?
thanks
Sal
Old Dec 2, 2008 | 06:01 AM
Evo Tengoku's Avatar
Bbk
Old Dec 2, 2008 | 06:16 AM
TurboRSX04's Avatar
cb
This is so true. I recently took off my gt35r kit and installed the stocker back on with full bolt ons and recently cosworth m2s and the car is alot more fun on the street. The gt35r is only fun 26 psi and up and since i wasnt going to build the block anytime soon i didnt want it to be on the edge where something can happen. And since these days the stocker can see 420 on e-85 u dont need no big turbo to get to 450. But the BBK might be something he should be looking at!
Old Dec 2, 2008 | 08:15 AM
ScorpionT's Avatar
From seeing dynos from FP green and BBK, I would say BBK.
Old Dec 2, 2008 | 02:27 PM
Davethewave's Avatar
Originally Posted by RyuEvoIX
I'm making 435whp with the stocker. Might wanna consider maxing it out before upgrading.
this gentleman is first class bull****, no sir you are not making 435whp on the stock turbo.
Old Dec 2, 2008 | 02:29 PM
CBRD's Avatar
here is an HTA 30R at 23.8 psi vs our BBK at 24.2 psi...
BBK is solid line
both cars had valvetrain upgrades, cossie cams, etc.. fmics...
it was about 25 degrees cooler for the BBK, but do you think that will bridge the gap? hee he..
cb
Old Dec 2, 2008 | 02:33 PM
^^ there u go that says it all
Old Dec 2, 2008 | 02:50 PM
RyuEvoIX's Avatar
Eat crow. This was back in mid summer weather. It's 30-40deg cooler now.
I ran 11.388@119.92mph and 11.39@120.38mph back when my car dyno'd 390whp on stock cams.
http://videos.streetfire.net/video/E...ock_157374.htm
Next time do your homework before raising the BS flag.
