anyone got IAT logs for perrin (or any non stock) intake
Hi Guys,
I am looking at getting the perrin intake kit, but want to make sure that it wont heatsoak more than the stock airbox.
anyone got any IAT logs for like idle+cruise+pull to compare the stock airbox vs aftermarket intake?
OR - is it possible to reuse the stock airbox with the perrin inside it?
any other ideas?
Cheers
Dave.
any other ideas?
Cheers
Dave.
The Perrin is a very good system; you'll be satisfied. Even when the intake temps rise as you sit and idle, once you get moving they drop very quickly due to good air movement in the engine bay.
I would just leave the filter open rather than closing off incoming air with a box. Intake temps at idle/not moving will raise a bit more with an open filter compared to the stock airbox, but you'll be shocked at how quickly the values drop with a little bit of movement in 1st gear. Ceramic coated exhaust manifold, turbine housing, and o2 housing are also great ways to help keep underhood temps down. I don't have any hard values, but when I pop the hood I feel a lot less heat rising than I did before the coated stuff.
WTB[SouthEast]: Stock intake with air box and maf
germanmike954
Jan 9, 2017 12:21 PM
[WTB] Evo IX Stock Intake Pipe
breadn56
Sep 28, 2015 06:41 PM
CharlieGsanD
Nov 8, 2004 10:00 PM
