evo gone wrong
Old Dec 6, 2008 | 04:35 AM
ROOKHOE's Avatar
does anybody know where there is a reputable shop where i can get a tune and buy car parts from near Quantico, Virginia?
Old Dec 6, 2008 | 04:46 AM
whoang40's Avatar
^^^^Try posting it in the regional forums your question.
Old Dec 6, 2008 | 06:17 AM
jmelocik's Avatar
I posted DTM's contact info in your other thread. Check em out. Great shop. Great guys.
Josh
Old Dec 6, 2008 | 07:31 AM
DTM's Avatar
DTM
There are many things it could be. I would check plugs first. While you are taking apart that area of the car look directly at the FPR (Fuel Pressure Regulator) and make sure that the Vac/boost lines are all secure and non have come loose. Sometimes the solenoid also fails and or has a broken end to it from faulty installs.
If you give me a call we can set something up or we can try and help you over the phone a bit too.
Old Dec 6, 2008 | 07:44 AM
2003lancerevo8's Avatar
Sounds to me like its an ignition issue. I would change the plugs, then if you did not get tuned, go get your self a xmas present
Did you get tuned after the install of your mods?
keep us posted
Old Dec 6, 2008 | 07:48 AM
Craig King's Avatar
Muffler bearings need re-greased.
Old Dec 6, 2008 | 08:51 AM
DIDYSIS's Avatar
wow I was so wrong the whole time, I forgot about those I better tear get into my cat and grease those things. but funny
Old Dec 6, 2008 | 02:30 PM
HyaboostaIX's Avatar
Yea I was in 5th gear the other day and I heard a loud pop too....my lower intercooler pipe blew off, lol. Seriously though, It is definately some sort of cut. I had my boost controller set too high and it was cutting me off as well. I turned my boost down to about 20psi and it runs like a champ. like everyone else was saying...could be plugs too.
Old Dec 6, 2008 | 04:19 PM
boosted2x2's Avatar
check egr valve and vac hoses going to it
Old Dec 8, 2008 | 09:27 AM
skibo84's Avatar
I had the exact same problem...either get a tune or take off your mods...you pick.
