Any benefit to reving over 8500?
Old Dec 8, 2008 | 02:49 PM
rEVoLed's Avatar
Currently, I am running a built bottom end 2.0 with a 35r, I'm planning on upgrading to a HTA35r along with some new cams, valvetrain. Current rev limit is about 8100, My question are:
Any benefits in reving to 9k or higher on?
What other mods would be necessary to make power at that type of revs? Obviously, cams, turbo and head but what about a ported stock or aftermarket IM w/ bigger TB?
What cams are recommended for high rev applications? Kelfords, Cosworth, S2's?
Old Dec 8, 2008 | 04:13 PM
ONRAILS's Avatar
a big IM will help make power on the bigend.
and s3's for higher revs. The only time i really see people go over 9k is when they run 4th out in the 1/4
Old Dec 8, 2008 | 04:58 PM
whitey4d's Avatar
The main reason why people spin there engine past 9K is usually to stay in 4th gear through the trap as ONRAILS has stated above. At high boost where most turbos are at their choke flow limit or close to it the torque started to drop out some at high RPM. Even with larger plenums, cams, and flowing heads there is a point where 600-700 whp cars still drop efficiency on 35 ish turbos. The only real execption to this are 42Rish turbos to even even need to go past 9500.
Old Dec 8, 2008 | 05:01 PM
ericblackevo8's Avatar
It also depends on what size exhaust housing you have.
Old Dec 8, 2008 | 05:06 PM
Erik@MIL.SPEC's Avatar
Isn't that something you can determine on the dyno and see if the car is still making power up top or not? That will tell you all you need to know for your particular set-up.
Old Dec 8, 2008 | 06:33 PM
Ted B's Avatar
A dyno plot of torque vs. rpm is all one needs to determine the optimum shift points for each gear. If the actual shift points are lower or higher, the car goes slower.
Old Dec 8, 2008 | 07:14 PM
Levar's Avatar
Veteran: Army
This website should help you determine where all of your power is once you get tuned and have a chart on hand.
http://www.bgsoflex.com/shifter.html
Old Dec 8, 2008 | 10:09 PM
rEVoLed's Avatar
Thanks for all the input as this is a hypothetically speaking since I have yet to upgrade the parts but I would image as stated above that a dyno will tell what the optimal shift points would be, I'm just trying to get an idea before I follow thru with the upgrades.
