Tial Bov spring?
Old Dec 18, 2008 | 08:51 AM
AcePitcher11's Avatar
Tial Bov spring?
I am getting ready to buy a tial bov but not sure which spring to get with it. I will be running around 28 to 31psi on pump and meth and probably 35psi on race gas so which spring would be best? Also how is the driveablility of this bov with an AEM?
Old Dec 18, 2008 | 10:04 AM
sizzflair's Avatar
I don't have Tial but when I had a Forge, it had different springs with different colors indicating different boost pressures... if Tial doesn't have a system like that, put one on test it out. If it surges, then move on to the next spring.
Old Dec 18, 2008 | 10:06 AM
TiALSport's Avatar
boost doesn't make a difference
what do you pull for vacuum at idle
Old Dec 18, 2008 | 10:10 AM
EVOLVEU's Avatar
if it were 12-14?
Old Dec 18, 2008 | 10:11 AM
EVOLVEU's Avatar
youll be fine with the AEM, just dont run a MAF (and if you do, it isnt that bad)
Old Dec 18, 2008 | 10:39 AM
TiALSport's Avatar
Originally Posted by EVOLVEU
if it were 12-14?
that is between two springs, 12-13 would be -7
14 would be -9 (or -8 if it were a Q)
Old Dec 18, 2008 | 04:36 PM
damn I am not sure what vacuum I pull. My car is down with the turbo and manifold off so I have no way of telling right now. How much are the springs so I could buy them and then return the ones I don't need?
Old Dec 18, 2008 | 05:40 PM
JakeTheVIII's Avatar
I have the Tial Q and on the side of the box it says Q11. I have an SC61 turbo and 280 cams on stock ecu with no problems.
Edit: I think I'm usually between -6 and -7psi at idle. Or -12 or -13 hg i guess.
Old Dec 19, 2008 | 02:08 AM
1NastyMR's Avatar
most cars use 9lb spring thats wat I got with 272 cams
Old Dec 19, 2008 | 06:35 AM
TiALSport's Avatar
you need an 8 psi spring
Old Dec 19, 2008 | 02:53 PM
RevMoto's Avatar
what spring for 18-20 vacuum?
Old Dec 19, 2008 | 11:20 PM
D-VO's Avatar
I just wanted to throw something out there for the Tial sport guy. I have a 7 lbs spring in my 50mm BOV. I switched from a 12 lbs spring that gave me a compressor surge issue. The 7 lbs spring does not hold boost past 23 lbs or 1.62 KG/CM^2. I can hear the boost leaking during a 5th gear pull. The vacuum chart didn't work for me in this case, in that my car reads 30 cm/hg or 11.8 in/hg and now has a boost leak issue when trying to go past 23 lbs of boost.
So, one's boost goal's should be a value to be looked at during spring selection. With that said, before I go back to the speed shop, how much boost does a 9 lbs spring hold? Given the information I gathered between the 12 lbs spring and 7 lbs spring, the 9 lbs spring should hold about 37lbs. Does that sound right? BTW, messing around with the 12lbs spring for the 50mm bov, I figured it is good for about 65lbs of boost. Does that sound right?
+ALSO RELATED+ After installing the 7 lbs spring I got a P0121 (Throttle Position Sensor/Switch A Circuit Range/Performance Problem) trouble code.
BTW TiAlSport, I don't want you to think I'm undermining you in anyway, I might just be a special case, but using the chart for the vacuum to select a spring did not work for me.
Thanks in advance for any help.
Old Sep 25, 2009 | 12:39 PM
BlueDemon's Avatar
Yeah, sorry for reviving this thread but I'm also having the same problem as the guy above me and it was right after installing a Tial 50mm BOV.
D-VO, did you fixed the problem after changing the springs on your Tial? Has anyone had a similar problem and would like to comment?
Old Sep 26, 2009 | 10:50 AM
D-VO's Avatar
Yeah, the nine psi spring was the best match for me in this case. Inever had the probelm again, and the bov holds 30 psi very well. The only thing is, I get a little compressor surge under nine psi, but from what I understand it's OK to have low boost surge.
Old Oct 3, 2016 | 01:50 PM
mines5's Avatar
My car idles in this much vacuum. Which spring should i use in TIAL q BOV ?
