Tial Bov spring?
Old Oct 4, 2016 | 11:01 AM
MasterNater's Avatar
Originally Posted by mines5
My car idles in this much vacuum. Which spring should i use in TIAL q BOV ?
-0.6 bar is about -17 inHg (vacuum). The Tial Q spring chart says to use the unpainted, or -10 Psi, spring for a vacuum reading between -19 and -16 inHg.
Old Oct 4, 2016 | 11:51 PM
mines5's Avatar
Thank you sir.
Old Oct 5, 2016 | 12:12 PM
evo8426's Avatar
I would go with the 8psi spring if I were you.
Old Oct 5, 2016 | 12:18 PM
mines5's Avatar
Please explain why not 10 psi ?
Old Oct 9, 2016 | 05:32 PM
211Ratsbud's Avatar
Trust him. Tial imho advertises over sprung ratings. Plus.. I set my bypass valves up to be light on the seat at idle. This helps improve response. You will have boost equalization on each side of the bypass valve and 8psi differential(the spring) should be sufficient to hold any valve shut at wide open. The trick is to have a valve to open correct under part throttle conditions. If you're hunting that it's another story. It's something I've learned how to do over the years, and no hijack intended ( the greddy fv was 10x the tial in drivable).
Old Oct 9, 2016 | 11:20 PM
mines5's Avatar
I want the bov to open every time i let off the throttle. After a WOT pull and variety of driving conditions.
My old bov [ HKS ssqv ] was good during part throttle operation but after a WOT or during sudden throttle lift off it wont open .
parkourpan
Nov 5, 2021 10:29 AM
Hiboost
17
Jul 19, 2019 09:01 AM
Bmurray
May 24, 2017 02:23 PM
lghtngyello03
Feb 6, 2017 11:00 AM
navr11
Mar 2, 2016 11:06 AM
