wga spring size for power goals?
Old Nov 9, 2017 | 03:05 PM
parkourpan's Avatar
i have a 2005 evo 8 with 125,xxx miles that i blew a head gasket on so now im doing my upgrades while im in there.
MODS- Evo is basically stock how it sits with tbe, cone intake, licp, twin disc clutch, evo 9 bov, and aluminum radiator.
Im rebuilding the head with new all gsc parts: s2 cams, valves, lifters, valve seals, seats, beehive springs and ti retainers with arp head studs.
New bolt on mods are bigger intercooler, ebc, radium fuel rail w/ pulse dampener, fic 1050 injectors, walbro 450 e85 pump, and an Arashi TD06hr-r2 turbo with kinugawa wga. plan on duel 91/e85 maps.
which bar spring should i get for the wga if my goals are around 500 hp? 1.2 bar? 1.5 bar?
also am i missing anything important in my setup?
do i need an omni 4 bar?
thanks
edit: aslo found this,
Originally Posted by 94AWDcoupe
If you are only using one port on gate I would recommend as close to boost spring pressure as possible. so if you run 30psi you want a 30psi spring if you can get it. reason being is fast spool is lost as soon as valve cracks off seat. on a 25psi gate it is likely cracking at 15psi with back pressure blowing it open. 1 bar spring starts to open at around 9 psi.
is this correct?
Old Nov 9, 2017 | 03:17 PM
e_kobz's Avatar
22psi
Old Nov 9, 2017 | 03:43 PM
parkourpan's Avatar
thanks for the reply
Old Nov 9, 2017 | 04:51 PM
hutch959's Avatar
i could be wrong... but dont you typically go for a spring that is about 1/2 of what your peak boost goal is?
Old Nov 9, 2017 | 05:15 PM
parkourpan's Avatar
ive read that as well. just finding conflicting threads and trying to get a concrete answer, but guess ill just get the 22 psi and if i need to change the spring up or down ill buy it later
Old Nov 16, 2017 | 06:39 AM
kpr's Avatar
kpr
The important part is just make sure its less than the boost you want to run. Example , if you want to run 30psi, set wasetgate to 25psi and use the boost controller for the rest. This way the controller shuts off vac going to the wastegate and can make the turbo spool a little quicker.
Old Oct 26, 2021 | 09:50 AM
Lion_Sam's Avatar
After several years using of Arashi anti-surge TD06SL2-ER-10.5, bought and installed used stock Evo IX turbo...
Now my Evo IV accelerating like never before, it's awesome. Boost up to 1.5-1.6 bar.
Arashi turbo wasn't go pass 0.9-1.0 bar on 1st and 2nd gear, but this go 1.2-1.3 bar easy
Old Nov 5, 2021 | 10:29 AM
racelab's Avatar
would depend on the fuel u would use and whos tuning the evo
Micheal Comeaux
May 20, 2020 02:04 PM
Nikoro
Aug 17, 2018 08:09 AM
AJR-Coco
11
Sep 6, 2009 08:45 PM
TurboTylerIX
Apr 28, 2009 04:41 PM
