wideband help ??
Old Dec 18, 2008 | 11:12 AM
strtrcng426's Avatar
wideband help ??
I have a bung on my hks exhaust after the test pipe...will i get accurate reading if i put the o2 sensor after the test pipe ? thankss
Old Dec 18, 2008 | 11:14 AM
travman's Avatar
the dp would be better but as long as its a test pipe and not a cat of any kind then the wideband at the opposite end would work.....if its the only option u have.
Old Dec 18, 2008 | 11:19 AM
thanks man
Old Dec 18, 2008 | 02:03 PM
Broxma's Avatar
As long as it is before any cat in the exhaust it will be fine. Wideband sensors measure a change, delta, lambda, whatever you want to call it, so as long as it is calibrated and before the cat in a closed system it doesn't matter where you put it. Most dyno facilities have a clip-on standalone WB setups which generally only go 6" to 2' up the back of the exhaust, used on catless exhaust systems obviously. They are equally as accurate as permanently mounted, in car systems.
More important is the clock position of the sensor which should be above 9 and 3 on the pipe itself. Below 9 and 3, the sensor is more likely to pick up garbage and condensation that is normally running down the bottom half of the pipe.
/brox
Old Dec 18, 2008 | 07:21 PM
Raif's Avatar
it will work, its going to be a bit later response on the gauge. If you dont have a cat it should not make a big difference at all.
Old Dec 19, 2008 | 08:14 AM
Tigre's Avatar
Raif... is dead on with his answer.
