OH BOY! No Good!
OH BOY! No Good!
Its backfiring because the car has no coolant in it, causing it to run very hot. If there is no coolant in there at all, its hard for the temp gauge to work right. You might need a head gasket now.
if it's the head gasket...are they hard to change yourself? I know you have to take the manifold off to do it however I still have my stock manifold on and it's never been taken off..Figured it would just be a pain in the *** however i know it's pretty straight forward. However car ramps are not gonna give me much room to work underneath if i have too
it does sound like over heating due to bad head gasket...
and to answer your question about swapping out gaskets. its a pretty in depth repair... and could be a lil overwhelming if your new to 4g63 platform
good luck man
good luck man
You will need to pull the head to replace a headgasket. You should consider replacing the head studs with stonger ones, like ARP. If it is in fact a headgasket that's wrong with your car. Make sure first.
