KOYO radiator real benefits?
Old Dec 19, 2008 | 06:54 AM
extremier's Avatar
Will KOYO radiator provides real more cooling than stock one?
My EVO 7 is used for trsck days in hot Brazil..
Mods. FP Green turbo, Cosworth M2 cams + more.
Thanks.
Old Dec 19, 2008 | 07:00 AM
JakeTheVIII's Avatar
With your mods and being in Brazil, it wouldnt be a bad idea. It will offer a little better cooling simply because it's larger and more efficient. I have a thick one, and can BARELY fit it with a larger turbo and wastegate. I'm switching back to stock, because it will fit with my setup.
Old Jun 28, 2009 | 07:46 AM
avo3vom's Avatar
Can the stock fan be used with the Koyo or do you need a slim one?
Old Jun 28, 2009 | 08:01 AM
TommiM's Avatar
the slim spal fans flow more air than oem from what I hear anyways. Even if you can fit the stock one, the aftermarket ones should be better.
Old Jun 28, 2009 | 08:23 AM
avo3vom's Avatar
Thank you
Old Jun 28, 2009 | 11:00 AM
red evo8's Avatar
bigger fan and running 100% distilled, no antifreeze, water since it doesn't freeze in brazil? Or you could hook up fan switch and keep it on when more cooling is needed.
Old Jun 28, 2009 | 11:06 AM
jude's Avatar
I believe coolant actually raises the boiling point of the water in the cooling system. Wouldn't be a bad idea to run a 50/50 mix.
Old Jun 28, 2009 | 11:14 AM
94AWDcoupe's Avatar
I have never found an after market slim fan the flows near the stock ones. Likely doesnt exist because the electric motor is shrunk in size. spal fans do no flow more than stock ones. they are at the top of after market though.
Old Jun 28, 2009 | 03:56 PM
TommiM's Avatar
They can if you wire them up to be constantly on( toggle switch) with the ignition on.
Old Jul 1, 2009 | 05:20 AM
94AWDcoupe's Avatar
not even close to true. I live in Florida. hardest state in US to keep car running cool. I have done sufficient testing of fans to know what I am talking about.
Old Jul 2, 2009 | 08:04 AM
TommiM's Avatar
Ya, I just meant that as a joke.
Old Jul 2, 2009 | 08:16 AM
InjectedPerf's Avatar
this
it also lubricates the water pump and prevents rust and corrosion.
evo209
Sep 23, 2015 09:37 PM
nismo3183
13
Sep 6, 2015 03:39 PM
kpt6
Jul 30, 2015 04:54 PM
kpt6
Jul 22, 2015 11:12 PM
Positron
10
Dec 12, 2007 07:01 PM
