Need help bad! winding and grinding noise..
Subscribe
Dec 19, 2008 | 10:44 AM
so last night i did my first pull in my car since my new act extreme clutch was installed, licp, full intake and dp back exhasut... i waited 300 miles of babying the car to brake the clutch in...
so i did a 3rd gear pull untill a little under redline then a pull all through 4th got back on the high way and in every gear now if u touch the gas a little it starts to wind and somtimes make a little grinding noise ???? sounds like its comin from the front.. it also does it in nutural if your rolling down a hill..
i have no clue what this could be please help me out thanks alot
-Jake
Reply 0
Dec 19, 2008 | 10:48 AM
Maybe the transfercase....
Reply 0
Dec 19, 2008 | 10:51 AM
doesnt sound good
i had the same promblem i have 22000 on my 2003 lancer and if it winds louder when you hit gas that could be t case only thing that makes that noise. I also have a exedy twin disk but that chatters no winding. Also really pay attention to it the more rpms the louder it should get and when you slow down out of gear it should wind down. Try that out if it does this could be your t case taking a ****. I just put a stage 3 from sheps in my car rated for 950 horse i will probaly never get near that but hey at least i dont have to worry about it. Hope this helps i know how you feel so just message me if any more questions.
Reply 0
Dec 19, 2008 | 11:13 AM
Quote: i had the same promblem i have 22000 on my 2003 lancer and if it winds louder when you hit gas that could be t case only thing that makes that noise. I also have a exedy twin disk but that chatters no winding. Also really pay attention to it the more rpms the louder it should get and when you slow down out of gear it should wind down. Try that out if it does this could be your t case taking a ****. I just put a stage 3 from sheps in my car rated for 950 horse i will probaly never get near that but hey at least i dont have to worry about it. Hope this helps i know how you feel so just message me if any more questions.
well the noise got a worse and worse untill i brought it home...
Reply 0
Dec 19, 2008 | 11:16 AM
also wat would cause my transfer case to blow ?
Reply 0
Dec 19, 2008 | 11:18 AM
Did ya put fluid back in it....was it the rt kind? maybe that clutch dump with the new clutch?
Reply 0
Dec 19, 2008 | 11:20 AM
i didnt do the clutch job a local shop did it pruven performance ? idk if u ever heard of them i would take it to them today and have them listen to the noise but there a huge blizzard where i live and id idnt take my car out i took the truck..
Reply 0
Dec 19, 2008 | 11:32 AM
bumppp
Reply 0
Dec 19, 2008 | 12:26 PM
bump for help
Reply 0
Dec 19, 2008 | 12:28 PM
sounds like the transfer case...
since your new clutch have you launced the car at all?
Reply 0
Dec 19, 2008 | 08:42 PM
nope ive only gotten on it one time since my new clutch but the ound is coming from the front i thoughttransfer case noise comes from the rear ... ?
Reply 0
Dec 19, 2008 | 09:05 PM
No, the transfer case is behind the transmission..in the middle of the front of the car so to speak. If you post a video of the sound maybe you can get more help...
Watch this video in this other thread. Does it sound like this
https://www.evolutionm.net/forums/ev...ase-noise.html
Reply 0
Dec 19, 2008 | 09:27 PM
check your fluids
Reply 0
Dec 19, 2008 | 09:29 PM
yup thats wat it sounds like but only the last 9 seconds of that video that whistle noise is wat i get.... ? thanks alot for all your helop man
Reply 0
Dec 19, 2008 | 09:33 PM
if it is the TC how much would this cost me ?
Reply 0
