Huge problem
Old Dec 20, 2008 | 06:26 PM
wevo1's Avatar
also the threads are stripped where the spark plug screws in
Old Dec 20, 2008 | 06:50 PM
Ivan@AMS's Avatar
I have seen this once before on an Evo. The spark plug may not have been installed correctly or threaded in all the way and it then worked its way out. It is very likely when it only had a few threads left holding it in the head, the explosion in the cylinder pushed the spark plug out messing up the last few threads in the head. It may be possible to get the spark plug back in without messing up the head any further. Call the shop on Monday and make an appointment. Get it towed over and we can look at it.
Do not attempt to force the spark plug back into the head. You can mess it up further.
Old Dec 20, 2008 | 06:52 PM
wevo1's Avatar
ok thank you but the problem is money all us evo owners are broke if they can get the spark plug back in you think there is more to it i mean my compression was only 90...its supposed to be at like 150 (at least on dsm's)
Old Dec 20, 2008 | 06:55 PM
Ivan@AMS's Avatar
How are you checking compression on that cylinder if the threads are stripped out?
Old Dec 20, 2008 | 07:06 PM
wevo1's Avatar
well thats true we did not realize that the threads were stripped and we got it to go in a little, tested it, took it out, and went to check the compression again and it would not screw back in...how much would it cost to look at it, do you have any idea?
Old Dec 20, 2008 | 07:20 PM
Ivan@AMS's Avatar
Assuming the threads arent too messed up, its a matter of running a tap in the head to clean the threads up. This needs to be done correctly or you can cross thread it which reduces the ability of the head to hold the spark plug in. The tap needs to be dipped in grease to keep any chips from falling into the cylinder. It should take less than an hour to get the threads sorted out (again, assuming they arent too bad) or to determine the head needs to be replaced. Fixing the melted wiring is hard to put a time on but I would assume less than an hour.
If you do not bring it to AMS, please have a reputable shop inspect / attempt to repair. The head can easily be messed up more than it is now. Too messed up and the head will need to be replaced which will not be cheap.
Old Dec 20, 2008 | 07:25 PM
wevo1's Avatar
so when i get it towed there do i need the money right away or would you guys hold my car until i got the money or what?
Old Dec 20, 2008 | 07:29 PM
Ivan@AMS's Avatar
I am just a mechanic in the back. I do not make those types of decisions. I would call and discuss your situation with one of the sales guys on Monday. I am sure they can work something out for you.
Wish I could be of more help.
Old Dec 20, 2008 | 07:37 PM
wevo1's Avatar
no way you have helped me so much thank you!
Old Dec 21, 2008 | 11:47 AM
sonicnofadz's Avatar
Just get a helicoil spark plug kit and you'll be good to go. Its way cheaper than a new head and it works perfectly. I've been through this a billion times on many different cars.
Old Dec 22, 2008 | 04:38 PM
wevo1's Avatar
how does that fix my knocking problem?
Old Dec 22, 2008 | 06:06 PM
VRSF Tiago's Avatar
You should learn to install spark plugs
I kid.
Keep us updated, I'm curious as to what the knocking problem ends up being.
Old Dec 22, 2008 | 07:27 PM
I'm not sure if your knocking problem is caused by a engine problem or a missing spark plug. If your car is missing a spark plug, there will definitely be a "knocking sound" so if you helicoil the messed up threads you should at least have the noise associated with that problem fixed. Having your combustion chamber exposed through the spark plug hole will definitely cause some racket to be heard from under the hood. Its hard to really tell what your problem is since we are unable to hear or see anything on your car, and you've done a pretty **** poor job of describing the problem due to your mechanical inexperience.
Old Dec 22, 2008 | 09:19 PM
wevo1's Avatar
well thank you for the idea im definitly going to try it before i get my car towed to ams, but sorry i dont know really anything about the engine and its kinda hard to explain something you dont know too much about and explaing incorrectly, and in return having false input
Old Dec 22, 2008 | 09:22 PM
VRSF Tiago's Avatar
No worries man, not everyone was born with all this knowledge
Even if you had a better idea of how things worked this kind of thing would still perplex most people.
