Huge problem
Old Dec 20, 2008 | 02:46 AM
wevo1's Avatar
Huge problem
OK so heres my problem... as i was driving...out of no where my engine makes this loud knocking noise almost as if a piston was misfiring...or something. as i increase throttle i makes it faster and louder, my wideband is saying too much gas(when im accelerating) but normal when im cruising. is it timing...piston...or what?? if you guys can seriously help me i can record it or something PLEASE HELPPPPPPP
Old Dec 20, 2008 | 03:04 AM
casper980's Avatar
Sounds like it could be spark plugs, when is the last time they were changed?
Old Dec 20, 2008 | 03:07 AM
casper980's Avatar
Why not call ams if they tuned it?
Old Dec 20, 2008 | 07:10 AM
Raif's Avatar
have you checked the oil in it. It might be a rod bearing.
Old Dec 20, 2008 | 08:44 AM
someguyonline's Avatar
boost leak, ?? If not maybe something mor serious like jumped t belt or broken piston. Really need more info , check the plugs, oil , timing (make sure the marks all line up) and look for boost leaks
Old Dec 20, 2008 | 09:02 AM
xhooniex83's Avatar
+1, that's your best bet. Noone can give you an answer just by reading ' loud knocking noise'.
Old Dec 20, 2008 | 10:28 AM
Mr. PSSsSt's Avatar
FCOTM Winner
call ams and have them look at it
Old Dec 20, 2008 | 10:33 AM
sonicnofadz's Avatar
If you are hearing a knocking sound, DO NOT DRIVE THE CAR. You are causing more and more damage to an engine which already needs to be rebuilt. If you continue to drive the car, I'm sure you will be not so pleasantly suprised by being left stranded on the side of the road with two fist sized holes in your engine block.
Old Dec 20, 2008 | 10:50 AM
porsherules911's Avatar
^i agree park the car until you can find out what is going on
Old Dec 20, 2008 | 10:54 AM
EvoJoeIX's Avatar
whats the wideband reading
Old Dec 20, 2008 | 12:15 PM
EvoDom's Avatar
knocking means something broke, period.
rod bearing, pistion, rod.
do not drive it, and call ams.
Old Dec 20, 2008 | 01:04 PM
andreww238's Avatar
^ agreed
Old Dec 20, 2008 | 05:08 PM
HyaboostaIX's Avatar
+1...hopefully it's nothing too serious, but don't risk hurting it if it's not already. You won't regret it.
Old Dec 20, 2008 | 06:23 PM
wevo1's Avatar
UPDATE.....when i woke up today i pulled off the spark plug cover and the 3rd spark plug from the left was completly shot out and the wires were burnt to ****. the spark plug gap was pushed all the way up and the threads were stripped...i checked the compression its at 90...haha. the wire harness to the right of the engine block that plugs into the spark plug wires was melted also.
Old Dec 20, 2008 | 06:25 PM
psphinx81's Avatar
thats not good.
