Trick to removing flywheel dowel pins?
Old Dec 20, 2008 | 09:30 AM
Nasty Evolution's Avatar
Well I was going to take my flywheel in today to get resurfaced and I can't seem to get the 3 dowel pins out. The backs of them are slightly exposed, so I tried to use a punch and a 3lb hammmer to tap them out. HA, they would not even budge. Put a little heat from a propane touch on the pins just in case there was any loctite used on them, but still no luck.
Flywheel is either a Pro Street 10lb or a Competition Clutch 10 lb. (not sure which one it is, came on car when I bought it.)
My only other idea is to try a press but since the acess to the pins is not a straight shot. Doubt I will be able to use this method when trying to press at an angle.
Old Dec 20, 2008 | 09:34 AM
wevo1985's Avatar
they can prolly remove them and reinstall them at the machine shop.
Old Dec 20, 2008 | 03:43 PM
tobz's Avatar
Just take it to them, they have a little tool they hit with a hammer and they come right out.
My guy charges 6 bucks for that, so I wouldnt mind that tool.
rstchris
10
Sep 18, 2013 07:44 PM
real fast
Sep 30, 2012 08:04 PM
Charlie-Y
May 16, 2011 07:21 PM
justboosted02
Jul 6, 2008 05:58 PM
ruzs
Sep 23, 2004 06:23 AM
