mbc location
Old Dec 20, 2008 | 08:50 PM
N3VO's Avatar
mbc location
what do you guys think of this location?
Old Dec 20, 2008 | 08:52 PM
EvoDom's Avatar
not bad. i have mine mounted where the UICP bolts to that bracket. very easy to get tooo....yours is nice to maybe ill switch? how is it sitting there?
Old Dec 20, 2008 | 08:59 PM
merlin00069's Avatar
Looks discreet but kinda....cramped.
Old Dec 20, 2008 | 09:01 PM
N3VO's Avatar
in between the battery and fuse box i drilled a small hole into the plastic (i think its plastic) wall, right next to the bolt to hold down the fuse box. i dont know what to call the wall. if you look at the first picture i just then bolted it down with the adapter that came with the forge
Old Dec 20, 2008 | 09:02 PM
N3VO's Avatar
ya its a little cramped but i figure i dont really need much room for it as it clicks at the top to +- boost
Old Dec 20, 2008 | 09:09 PM
vmrevo9's Avatar
Veteran: Air Force
nice spot, i have mine on the bracket that the UICP bolts to.
Old Dec 20, 2008 | 09:27 PM
Casper.'s Avatar
I have mine on the drivers side of the radiator, where theres a bolt that connects near teh headlight. It looks perfect, and very easy to access, its just right there. I recommend everyone mounting it there, ill get pics if you want.
Old Dec 20, 2008 | 09:30 PM
19DB794's Avatar
take a pic. I wanna see where it is.
Old Dec 20, 2008 | 09:34 PM
Casper.'s Avatar
let me go out there now and snap a pic..im bored and need something to do lmfao
Old Dec 20, 2008 | 09:42 PM
sikrsix's Avatar
I like it. Easy enough to get too, and yet hard for others to mess with. (car shows, drag strip and have the hood up) I have mine bolted right next to my koyo on the drivers side as well. both good spots.
Old Dec 20, 2008 | 09:46 PM
Casper.'s Avatar
here ya go
Old Dec 20, 2008 | 10:00 PM
19DB794's Avatar
Thats a nice mounting spot. I think im gonna mount my MBC there as well. Where did you run the lines from the MBC to? I know theres a few ways to install them but im just looking for the best way right now.
Old Dec 20, 2008 | 10:03 PM
N3VO's Avatar
me or casper?
Old Dec 20, 2008 | 10:05 PM
19DB794's Avatar
Either one. I remember reading through a thread that explained the pros and cons between installing them either way but I cant find it now.
Old Dec 20, 2008 | 10:13 PM
Casper.'s Avatar
i just used a hose connector and ran it under the air box, so you cant see anything. And then to the wastegate, and a boost source
