cut out?
cut out?
this is the second time this has happened to me both in cold weather...
was taking off (wot) from a toll booth and all the sudden at around 4-5000 it cuts out almost like a rev limiter .
dont know what it may be possibly runnin very very lean ? mods are tbe,o2housing,uicp,ntake,aps dual vent,NO TUNE YET ,lc-1 not hooked up yet
any ideas?
any ideas?
a tbe and o2 housing and intake without a tune? and no boost controller?
could be overboosting thats leading to the fuel cut
get a boost controller and turn the boost down a tad bit...if that doesnt work get a tune
na both times i had been driving for a while and it was the first time during both trips i went wot through both gears or at least tried both gears (2nd-3rd)
maybe boost creep ,i got a cheap boost gauge that sometimes says im boostin at 25psi but im pretty sure its way off(p.o.s)
get a MBC..they are cheap...turn down ur boost to stock VIII psi which is 15 psi i believe and see what happens. if it still happens...get ur thing tuned buddy...i wouldnt do all those mods without a tune...my engine will just be asking for it.
Sounds like "Boost Cut" to me... I had my first taste of it this weekend. W/ the cold weather ~ 20*+ cooler, I overshot boost by 4 psi... Not good! I had to turn her down.
I think it would be wise to tune for cold and warm temps. Seeing that boost fluctuates this damn much...
get a boost controller and lower your boost...get your car tuned before you blow it up...you shouldn't be beating on the car with all those mod and no tune
wastegate boost is 12 psi
it's closer to 18 psi
