wierd noise at idle (maybe cam gears)
Old Dec 24, 2008 | 02:54 PM
vmrevo9's Avatar
Veteran: Air Force
Hey guys i had noticed a noise coming from the cam gears section at idle i recorded a video. its kinda like a grinding/rubbing soundi think its coming from the exhaust side but i'm not sure. hoping someone has heard this before and can let me know what they found.
http://www.youtube.com/watch?v=la5xlvEywXA
http://www.youtube.com/watch?v=LV5V3...e=channel_page
Old Dec 25, 2008 | 04:25 PM
Malik_EvoIX's Avatar
bump i wanna know what it is................
Old Dec 25, 2008 | 04:26 PM
huevosrancheros's Avatar
bump for some info as well
Old Dec 25, 2008 | 07:22 PM
XK120's Avatar
Large thread on this HERE. Lots of us IX owners seem to have the same issue...
Old Dec 25, 2008 | 10:21 PM
vmrevo9's Avatar
Veteran: Air Force
hey thanks XK120. at least i know its something simple. i'm gonna try and get some belt lube tomorrow and hopefully the sound will be gone!
Old Dec 26, 2008 | 10:21 AM
Muad's Avatar
vmrevo9, I had a similar sound that I dealt with on my car for about a year, then my timing belt tensioner let go and my car jumped timing (pistons hit the intake valves slightly)
I can't say for sure that's what was making the sound (tensioner pulley slowly going bad), but after I had my car fixed and put back together by Dan the man at BR, I don't have that sound anymore
p.s. I did not check out that thread that someone posted above...
Old Dec 26, 2008 | 03:25 PM
vmrevo9's Avatar
Veteran: Air Force
Hey Muad,
thanks for the info i'll probably be checking the tensioners soon. i bought some belt conditioner and sprayed the inside of the timing belt on the cam gears, and as soon as i sprayed it the noise went away. i'm definitely keeping an eye and ear on it for sure.
Old Dec 28, 2008 | 01:32 PM
vmrevo9's Avatar
Veteran: Air Force
well here is an update. i conditioned my timing belt. i had sprayed a little bit on the top of the belt while it was moving and i didnt noticed a difference. so i decided to spray a bit on the actual cam gears and the noise instantly went away. now the noise came back and it seems to be whens it's cold only. yesterday i had used the car to go to store and when i came back the noise was gone. i got some spray on the serpentine belt and now it whistles lol. so i plan on taking it off and inspecting the tensioner and cleaning the pulleys as well. i might as well change the serpentine belt while i'm there. in and all it might be the timing belt tensioner so i think i'm gonna start looking for a good shop and try to get it replaced soon.
Old Dec 28, 2008 | 02:34 PM
monkey_187's Avatar
My car does the exact same ****, I thought something was wrong. I came home on R&R from Iraq and the noise started 2 days before I had to come back. I thought it made the noise cause nobody uses my car. My family starts the car for me but I thought it started making the noise cause I was driving it again. I will see if it still makes the noise when I get back and start using it again.
Old Dec 28, 2008 | 06:15 PM
Muad's Avatar
THe noise also got louder for me when it was cold. Again, I'm not 100% it's the tensioner, but it seems since mine has been replaced the sound is gone.
I will add that I had Dan at BR put all of my stock pulleys and cam gears back on, as I had aftermarket before.
Old Dec 28, 2008 | 06:19 PM
vmrevo9's Avatar
Veteran: Air Force
i was just looking at some timing belt kits and i dont know who to go with. i think i might as well up grade to a Kelvar belt and might as well change out all the pulleys and tensioners. do i need to replace the water/oil pumps as well?
Old Dec 28, 2008 | 06:26 PM
Muad's Avatar
Well, I had the Greddy Kevlar, and Dan said he personally runs OEM. So he took all my Greddy Kevlar belts off and put OEM belts back on. I trust his opinion
Mind you, he could have sold me the more expensive ones, and he didn't. Yet another reason I highly respect him.
Old Dec 28, 2008 | 07:41 PM
vmrevo9's Avatar
Veteran: Air Force
i might give them a call or drop them a PM and see what they recommend. i'l check other places too. i think BR and AMS were one of cheapest with the OEM kits
Old Dec 28, 2008 | 07:44 PM
vmrevo9's Avatar
Veteran: Air Force
hmm i think you and Muad are the first 8 owners that i have read of that may be having the same issue.
hopefully it's something simple but if not i guess its time to upgrade lol.
BTW stay safe in Iraq. I'm active in the AF.
Old Dec 29, 2008 | 12:26 PM
Mellon Racing's Avatar
I'd go with Muad's suggestions on this, take it very seriously, it could be the precursor to something very bad.
