Car shaking and vibrating..wtf is wrong
Old Dec 25, 2008 | 01:56 PM
MTRJunior's Avatar
theres nothing stuck on the wheels, I didnt even go through any ice, it was raining the whole day so there wasnt really any snow/ice on the road
Old Dec 25, 2008 | 05:01 PM
gsrboi80's Avatar
Get under it and check the driveshaft out. Make sure nothing came loose
Old Dec 25, 2008 | 05:11 PM
Abizzle's Avatar
Ya dude if you want, ill check it out... Ill be at Putnams Auto body for most of the day tomm.. So shoot me a pm and let me know whats good.. We can check the drive shaft, its only four bolts...
Old Dec 26, 2008 | 12:22 AM
sonicnofadz's Avatar
Jack the car up onto four jackstands and run the car with the wheels on. You will see whats causing the vibration. Its easier to do this on a lift though. My guess is that they boogered up the driveshaft install, or maybe forgot some lugnuts on your wheels. If I were you I would have just made a u-turn and just brought it right back to the shop and told them to fix it. That is actually what you should have done.
Old Dec 26, 2008 | 09:14 AM
cthcky5's Avatar
check all ur wheels, mine were not torque down probly and cased a violent viberation and violent shaking
Old Dec 26, 2008 | 12:23 PM
MTRJunior's Avatar
PMd ya!
Old Dec 26, 2008 | 02:11 PM
DarksideEng's Avatar
Also, check the axles. I once had an axle boot get torn and the grease flung out, which caused a heavy vibration at around those speeds.
Old Dec 26, 2008 | 06:12 PM
cfdfireman1's Avatar
The rear u-joint is hitting your after market exhaust this only happens in the rain and has been discussed here before more than once.
Old Dec 26, 2008 | 06:16 PM
wevo1985's Avatar
so what was it?????
Old Dec 26, 2008 | 07:32 PM
MTRJunior's Avatar
i wish i knew lol, still havent gotten a change to have it looked at
Old Dec 26, 2008 | 08:52 PM
jahnnybravo's Avatar
Do you get the vibration only during acceleration at the lower speeds? If so, I'd usually suspect an inner axle joint (tripot, cv, whatever you'd like to call it). But with the info you've given, I'd check with the new 2 piece axle shaft that you had installed. If the shaft is not the correct length (perhaps the wrong shaft for the application), you will definitely get a violent vibration. Seen it a few times personally, and recently I had worked on an Eclipse that had a shudder on acceleration and it turned out to be an aftermarket performance axle that was just a bit too long. If the shop still has your original axle, have them install it back in your car to see if that's the problem.
Old Dec 26, 2008 | 09:06 PM
Gumby56's Avatar
you fix it yet???? good luck
Old Dec 26, 2008 | 09:49 PM
backcountryGSX's Avatar
wheel weights?
Old Dec 26, 2008 | 09:59 PM
sdfontanini's Avatar
Originally Posted by backcountryGSX
wheel weights?
+1 maybe this easy
Old Dec 26, 2008 | 10:18 PM
wheel weights?
Doesn't look like it. Wheel balance problem is usually 50 mph and higher. A separated tire is more likely, happens at lower speed, but both usually aren't violent. I'm still banking on the axle.
